? is 1989 accord bolt pattern
Old May 31, 2013 | 10:05 PM
89ED's Avatar
Default ? is 1989 accord bolt pattern
i just read it was 4x103 and i remember putting them on my ef while it was being parted out. so i never drove with them on the car and if i remember correctly they sat on there about 98 to 99% flush. i also put the ef alloys on the accord and if i also remember correctly those had to be wiggled on but they drove with no problems. what are your thoughts from a safety standpoint?
Old Jun 1, 2013 | 12:24 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: ? is 1989 accord bolt pattern
103mm? Never heard of that. There is 4 x 100mm and 4x 4.25"(~108mm) Fairly sure pre '90 Accords just used the 4x100mm BP. Simply take a ruler/tape measure and measure the distance between the center of opposite studs. Done.
Old Jun 1, 2013 | 09:14 PM
89ED's Avatar
im sorry i meant 4x100.3
Old Jun 2, 2013 | 02:13 PM
MAD_MIKE's Avatar
MM Gruppe B
.3mm is teeny tiny miniscule when it comes to wheel fitment, it would be split over the distance of the two studs. This would not cause wiggling on issues. The only thing I would check is that the register bore is the correct size.
4g4dcruisin
May 10, 2012 01:02 PM
jdm_handa
Suspension & Brakes
10
Jan 4, 2012 11:05 AM
GRAVEDIGGER
Jul 8, 2010 12:00 PM
4DRmafia
10
Jul 23, 2004 06:24 AM
Echo7847
Apr 2, 2003 12:59 PM
