Honda Civic Ex hard to start
Old May 31, 2013 | 06:41 AM
trekklee's Avatar
Default Honda Civic Ex hard to start
Hi I have a Honda Civic Ex and it is very hard to start everytime i would have to press all the way down on the gas pedal to start it up i changed the idle air control vavle and the throttle body and all the stuff under the roller and cap and the fire is not sparking blue it's sparking yellow which is not right. It can brearly whole its idle i would have to hold the gas pedal to keep it running but once it get hot its easy to start but idle kinda low
Old May 31, 2013 | 07:02 AM
B_Swapped93's Avatar
Default Re: Honda Civic Ex hard to start
sounds like a weak coil. WHY did you replace ALL that stuff could have saved a bit of money. stress test the ign system with a HEI tester. but at the same time how new is your plugs,cap.rotor and plug wires
Olibo96EX
Nov 3, 2017 04:44 PM
Jayrod
Feb 15, 2015 09:45 PM
Apple395
21
Jun 22, 2014 10:24 PM
hondacivc17
Honda Civic (2001 - 2005)
Mar 16, 2013 11:21 AM
