Jdm vtec oil pressure switch bypass help
Old May 30, 2013 | 05:13 PM
Miguel613ekb18c's Avatar
Default Jdm vtec oil pressure switch bypass help
Hey guys in the process right now of doing my b18c type r engine swap into my Canadian civic si
I'm using the civic harness but I'm confused about the vtec oil pressure switch bypass my ecu is odb2b
How do I bypass the switch pls help
Old May 30, 2013 | 09:20 PM
thirsk66's Avatar
Default Re: Jdm vtec oil pressure switch bypass help
Here you go this is how to do it on an obd1 ecu/ engine harness. Its the same for the obd2 engine harnesses. And here is the ff-squad obd2b civic & integra ECU pin schematics for hybrid swaps, you will be only looking at the vtec pin outs highlighted in RED. Goodluck. http://www.ff-squad.com/tech/wiring/wiring.99-01.jpg
Old May 31, 2013 | 01:39 AM
HondaPartsHero's Avatar
Technical Hero
If you're using the JDM ITR ECU it's not going to look for the pressure switch so you won't have to do anything.
Old May 31, 2013 | 02:13 AM
Thanks this really helps ill just jump the wires by the ecu
mik101
Jun 21, 2007 07:36 PM
rockinTheDOHC
Mar 30, 2007 03:11 PM
GummyBeng
Feb 17, 2003 08:18 AM
Backmarker
Aug 30, 2002 01:23 PM
