What do i need to swap a J30 into my 95 accord V6?
Old May 30, 2013 | 04:21 PM
adamwulfe's Avatar
Icon6 What do i need to swap a J30 into my 95 accord V6?
I have a 1995 Honda Accord V6 and recently found out one of my lifters was bad. My car has a stock C27 in it and I know this engine is bad for this. I also know I'm Better off replacing all of them. Instead of doing all that and worrying about other problems popping up, a friend offered me his J30 out of his newer Vtec Acura. What do I need to do the switch. I know his engine is just a newer version of mine basically (I say lightly) so I'm told they are compatible.
Old May 31, 2013 | 06:40 AM
Shmallow's Avatar
Default Re: What do i need to swap a J30 into my 95 accord V6?
sorry, not even close. the biggest similarity between the two engines is that they are V6s... they are from different engine "families," J and C.
it's not impossible to put a J30 in place of a C27, but it's not easy , straighforward or even advisable.
as i see it your two best options to chose between are to bravely attempt to fix the C27 you have or cut your losses, dump the car and find something else.
Old May 31, 2013 | 01:51 PM
MAD_MIKE's Avatar
MM Gruppe B
I thought some nutjob put an Acura Jseries + 6 spd into their CD Accord. Or was that a CG?
Old Jun 1, 2013 | 04:49 AM
Shmallow's Avatar
keyword: "nutjob"
haha.
Old Jun 1, 2013 | 03:54 PM
doc500's Avatar
Shmallow is correct. Anything is possible... Just not that easy. You would probably have an easier time swapping in a c30. Then again, I do not know. The J series and C series have different cylinder bank angles.
acc89
Jul 12, 2007 06:45 PM
The Civic Project
Jan 7, 2004 09:57 AM
DrunkNRacer
Dec 29, 2002 08:37 PM
