why are rdx injectors still refered to as 410cc?
Old May 29, 2013 | 04:39 PM
raverx3m's Avatar
Default why are rdx injectors still refered to as 410cc?
where is that number coming from?
according to this page they are nowhere near 410cc at stock(55psi) pressure more like 500cc
http://www.onecamonly.com/showthread.php?t=1895
but most people keep setting the injector size to 410cc
Old May 29, 2013 | 05:10 PM
locash's Avatar
Default Re: why are rdx injectors still refered to as 410cc?
Most injectors are rated at 43.5 psi, not 55.
Old May 29, 2013 | 05:12 PM
raverx3m's Avatar
check the 43.5 psi its still not 410cc
its close to 440cc
the stock pressure for rdx is 55psi not 43.5
Old May 29, 2013 | 05:14 PM
doood's Avatar
been there done that
mine are set at 390cc
Old May 29, 2013 | 05:17 PM
odz-fab's Avatar
you will find variances between many advertised injector rates vs actual flow.
Old May 29, 2013 | 05:24 PM
93supercoupe's Avatar
i dont really understand this thread. 410,440, 500, whats the difference?
Old May 29, 2013 | 05:31 PM
raverx3m's Avatar
are all the following linear?
flow from increasing fuel pressure
injector size in Neptune settings from smaller to bigger injectors
and overall trim
if I increase pressure and increase injector size to what its flowed at in the above chart(500cc at 55psi) and decrease overall fuel trim to match the idle afr will the injector still flow same everywhere else?
you understand what the difference is between stock Honda injectors and rdx injectors?
what youre saying is. similar to b16 b18 b20 whats the difference...
Old May 29, 2013 | 05:49 PM
SPOOLINmatt's Avatar
OYYY
ID1000 flow as high as 1500cc at 100 psi. Come on guy.
Old May 29, 2013 | 05:57 PM
raverx3m's Avatar
Old May 29, 2013 | 06:31 PM
I'm just saying, your argument is retarded.
The flow volume is skewed on ALL injectors.
Old May 29, 2013 | 07:00 PM
raverx3m's Avatar
maybe you just don undestan what I asked brah.
read again
Old May 29, 2013 | 07:01 PM
raverx3m's Avatar
its obvious all injectors flow different at different psi and voltage. not what im asking
Old May 29, 2013 | 07:31 PM
W T F
Old May 29, 2013 | 07:45 PM
raverx3m's Avatar
tard
im asking why do we even need the flow number if it doesn't matter in the tuning sorftware since a lot of people use different settings for injector size which are not even close to what they are rated at.
or does the injector size setting affect sometning in a different way than overall fuel trim
Old May 30, 2013 | 02:58 AM
grumblemarc's Avatar
The Grumpiest
Why do people call all 6th gen Civics EKs when they aren't? Sounds like the same thing here.
Old May 30, 2013 | 03:02 AM
Uncle Dave's Avatar
Most of the newer software uses the what injectors they are and what pressure your running to set the correct deadtimes or battery offsets or whatever they call them in there programs.
Old May 30, 2013 | 07:13 AM
raverx3m's Avatar
so the injector size is linear increase/decrease just like final multiplier?
Old Jun 9, 2013 | 06:42 PM
raverx3m's Avatar
has anyone else flow tested rdx injectors besides the link above?
seems like only 2 people in the world that had them tested.
Old Jun 10, 2013 | 01:14 AM
Uncle Dave's Avatar
PM DDTECH Derek had alot of good info that someone had done RDX testing.
Old May 10, 2020 | 11:58 PM
Emanuel Rivera's Avatar
i now this much stock pressure for ya car no where near non them maybe thats why 97 acura integ ls is like @ 23lbd 240cc
31 LBS IS 440 sopozly what it is it says if u dont have a fuel pressure regulator dont think it matters cuz u cant adjust your stock fuel PSI
all-mtr-teg
Apr 14, 2007 07:34 AM
Nikoli
Apr 6, 2005 01:33 PM
Sprockets
Jul 29, 2004 07:38 AM
sparq
Jul 30, 2003 01:57 PM
VTC_CiViC
Oct 6, 2001 10:43 AM
