b16a2 eg swap
Old May 29, 2013 | 04:52 AM
antvtec1's Avatar
Default b16a2 eg swap
my heater unit relay, rear de mist relay,cooling fan relay the 7.5a fuse they use has no power and all of the above dont work but all other fuses have and everything else is working fine any ideas??
Old May 29, 2013 | 04:54 AM
jbpnoman's Avatar
Default Re: b16a2 eg swap
Get a voltmeter. Start back probing behind the fuses that aren't getting power on the hot side using the chassis for ground, to verify you're getting 12V on them.
Old May 29, 2013 | 05:19 AM
antvtec1's Avatar
thank you will check back once done
skylierwood
Sep 1, 2012 04:26 AM
khock3
Mar 16, 2009 09:32 AM
ser13
Dec 26, 2007 12:58 PM
instrument
Nov 3, 2007 02:26 PM
