Ek coilovers on ef
Old May 29, 2013 | 12:18 AM
memo_ej8's Avatar
Default Ek coilovers on ef
I got some function & form type 1 coilovers for an ek, will these fit en ef? Has anyone tried it? Any info would be great
Old May 29, 2013 | 02:01 AM
Eks_86's Avatar
Default Re: Ek coilovers on ef
wat yr is ur ef the fronts should line up the rears it depends
Old May 29, 2013 | 02:21 AM
memo_ej8's Avatar
It's a 88
Old May 29, 2013 | 09:32 AM
Tyson's Avatar
this a noob question.
http://lmgtfy.com/?q=ek+shocks+on+ef
http://lmgtfy.com/?q=88+crx+rear+lca
short answer, only the fronts if you use EG/EK forks. and although you can make it fit in the front, its a detriment to your EF suspension so not recommended.
if you have any questions, read the many other threads on this subject.
yellowjdmcrx
Apr 22, 2008 12:59 PM
rjones
Suspension & Brakes
Mar 4, 2008 02:16 PM
RMXmitch
Jan 2, 2007 07:34 PM
MotoCARR
Suspension & Brakes
Mar 8, 2006 11:49 AM
phan
Aug 11, 2003 12:09 PM
