2008 si cambered
i want to camber my 2008 honda civic si sedan this is my daily driver im starting to build my civic nd want to get it cambered i wana kno which is the best camber kit to buy for my car aswell as what r the pros and cons
yea i was not sure what the reason for cambering was for thats y i asked on here i like the way it looks but i am only worried about performance at this point thats y i asked and if its only for looks then i dnt wana do it but i still never got a good answer owell lol
Adding negative camber to the front will help with our cars. However, the only way to add some in on stock suspension is with camber bolts. Go read up on alignment specs and their effects on handling, namely: camber, toe, and caster.
There's tons of resources on the web - a little bit of research goes a long way.
To add...
The reason you would want a camber kit when you lower your car is to help correct it so you can have a perfect balance in terms of performance and tire wear. A camber kit will help your car to handle like its on rails but it can also make you chew up tires like crazy.
The most important thing to remember is to bring it someone who is qualified at doing car alignments and mostly high performance alignments cause the specs are completely different then the ones on your daily driver.
I know he said it's his daily but from the rest of his post I don't think he understood what the complete purpose of a camber kit was. I decided to educate him!
I see a reason - for better handling. I've heard that a front camber kit and a rear sway bar can make a big difference on a Si with stock suspension, and it makes sense. The Si has decently stiff OEM suspension, what it lacks is negative camber and a thick sway bar in the back.
To add...
so what are you trying to do here you would get negative camber from lowering camber kits are to correct that and as far as im concerned the pros are not really anything unles yur looking for "stance" the cons are well going through tires and if your low pro than that gets expensive and as far as performance suspension most anything will lower it at least .7 the lower you go generally the more negative camber youll get camber kits are to straiten your wheels back out for increased grip and less tire wear
hey all, i am new up on this forum and on the whole "suspension" world. i have been trying to do my own research bc people seem to get pretty upset about it if u dont and ask questions.
anyways, i plan on dropping my car 1.5 inches, 18x8 +35-43 mm offset and 225 tires, fenders rolled, suspension would be either quality lowering springs like eibach sportlines with koni shocks or good coilovers. i was gonna try to run "stock" alignment camber settings with 0 toe.
any input on the camber part with the wheel spec i listed and 1.5 inch drop? will i need to add negative camber to prevent my tires from wearing out too fast or can i use stock settings with that wheel spec and drop and be good to go? i DD a lot and want very minimal tire wear.
