my partner wont start ;(
Old May 28, 2013 | 06:10 PM
fivecrew123's Avatar
Default my partner wont start ;(
Hi guys hoping you can help me with my current problem.
This morning i tried to start the car turned the key on everything works fine as normal lights,radio,etc, but when i tried starting it has the click sound but has no crank so the car wont start but before all of this yesterday when i started the car it turned on but it had a weak crank but it started and i drove as normal then this morning this happened. Btw my ride is a 2000 honda civic sohc engine. Any help will gladly be appteciated.
Old May 28, 2013 | 06:12 PM
RT_NEWYORK's Avatar
Default Re: my partner wont start ;(
starter? btw manual or auto tranny?
Old May 28, 2013 | 06:17 PM
Manual tranny sir. Yesterday when i started the car it started but the crank was weak.
Old May 28, 2013 | 06:20 PM
n/a2boost's Avatar
Bad battery,bad connection or bad starter.
Old May 28, 2013 | 06:21 PM
RT_NEWYORK's Avatar
can you roll start it by popping the clutch?
Old May 28, 2013 | 06:29 PM
What are the main signs if the starter is bad? Incase it is bad is it easy to change by myself?
Old May 28, 2013 | 07:42 PM
B_Swapped93's Avatar
it's very easy maybe 15 min job at the most
Old May 28, 2013 | 08:01 PM
Reaper2387's Avatar
Sounds like the battery is done. you can pull it and autozone or any like place will test it for free.
Old May 28, 2013 | 08:37 PM
Koko4's Avatar
Take your battery off and get it charged at AutoZone..takes like an hour. If it is still just doing that "click" when you turn it over, get someone to tap your starter with a wrench or other metallic object, while you try to start the car. Starter would be easy to replace yourself, but this could buy you some time. Sometimes it gets a little stuck and just needs some coaxing..
Old May 29, 2013 | 02:00 AM
Thanks for the input guys,gonna test my battert tommorow,may il just change the starter myself if thats the culprit incase.
ReVeNgEd-SoN
Jan 2, 2010 08:17 AM
Dave_Dc2
Oct 7, 2009 03:01 PM
blackcivic11
Jun 2, 2009 04:16 PM
allsho
Aug 5, 2008 04:30 PM
PuiPui
May 5, 2005 03:27 PM
