JDM Foglight question.
straight to the point...
I have a set of JDM foglights installed and they work fine. I have them set to turn on with the parking lights and stay on with the high beams. What I want, is for the fogs to turn off when the high beams come on. I have the harness that is plugged into the fuse box (near the drivers left foot/leg) set to ports 2 and 5 currently. Does anyone know what port numbers I can put the two plugs in so as to allow me to have the fogs go off when the high beams come on?
best bet is to do it manually - sorry. I know if you wanted them to turn off when high beams came on it would involve alot more wiring. This happened when my uncle was installing the OE fogs on his rsx-s - it was alot more complicated than ours.
Well, I thought I remembered someone saying there was another way to set up the fogs so that they would go off with highs. The reason I ask is that they wont pass inspection. If the fogs dont go out automatically, when the high beams are activated, the car will not pass inspection. In fact, I had to completely remove them from the car b/f it would pass last year. I was just trying to find a way so that I didn't have to remove them from the car this year....its a pain in the ***.
[Modified by Gen Five, 3:04 AM 10/25/2002]
Anyone know where I could find the answer?
