Rear lower control arm outer bushing NEEDED!
Old May 27, 2013 | 07:40 AM
carma42's Avatar
Default Rear lower control arm outer bushing NEEDED!
I have been to all parts stores and googled and googled. Can I get just the bushing on the inner or out of the lower rear control arm. I have no need for complete control arms if not necessary.
Old May 27, 2013 | 07:43 AM
carma42's Avatar
Default Re: Rear lower control arm outer bushing NEEDED!
I know I can find aftermarket bushing kits made of poly and so on but I am looking for an oem bushing and all the parts stores show the strut to arm bushing which looks different.
Old May 27, 2013 | 08:08 AM
S2BumpsticksGSR's Avatar
Parts geek.com- They'll send you an oem piece. OR go to dealer and get oem bushing minus upcharge/shipping/gas to get there.
P/s- all you need to press it in is a good vise and two big sockets. Its harder to get out than in.
Old May 27, 2013 | 08:29 AM
Fnix's Avatar
New LCA is only 60 bucks. Might as well replace them all without having to deal with pressing them in and out.
Old May 27, 2013 | 01:59 PM
AaSa's Avatar
agree with Fnix,it would be easier
Old May 27, 2013 | 02:39 PM
Op- yes. Inner/outer lca bushings are same on your lca and center (strut) one is different. Hope this helps
Old May 28, 2013 | 09:26 AM
xile6's Avatar
Easy to install got mines from autozone and use a ball joint c clamp type press to push it in. Only cost me $35 but autozone does rent them but don't know how much.
Old May 28, 2013 | 10:12 AM
dirty19's Avatar
Ridin Dirty in Cali
What kind of LCA is that? It looks like stamped metal.
Old May 28, 2013 | 11:20 AM
Fnix's Avatar
The part number is 52622-SH3-013 and yes they can be replaced individually.
Old May 28, 2013 | 11:28 AM
kyden's Avatar
oem 96-00.
Old May 28, 2013 | 11:35 AM
sleepyaccord96's Avatar
the bushing i always end up replacing is the one that the rear strut actually uses...usually the inner and outer are ok, its that damn center bushing that always adheres to the strut bolt and when you try to remove the bolt, the head snaps off. :/
Old May 28, 2013 | 01:31 PM
cvcrcr99's Avatar
I thought all 96-00 LCA bushings were the same?
EG/DC were the odd ball with the 84mm bolt going through the bottom of the strut and 80mm bolts elsewhere.
Old May 28, 2013 | 06:35 PM
Get some of the brush on type anti-seize and apply it liberally next time.
Old Nov 7, 2017 | 01:00 PM
Baby99EX's Avatar
so wtf how do i take them off??
Old Nov 7, 2017 | 01:22 PM
civic402lx's Avatar
Did u not read through the thread i posted to help you in your own thread? Burn out the rubber bushing. Cut a slit in the sleeve. Hammer out the the rest. If rubber material still intact then press it out with pressing tool. Go to YouTube, search and watch some vid. Get familiar with the process.
Old Nov 7, 2017 | 04:03 PM
Baby99EX's Avatar
so what is it a definite thing im going to get those metal bands? i wanted to avoid those......
Old Nov 7, 2017 | 04:14 PM
S2k@9K's Avatar
Yes, the rubber is "mated" to the sleeves. Take it to a a shop with a press and have them press out/press in or burn the rubber out, cut a slit in the sleeve and tap it out with a hammer and flathead and take to a shop with a press and press the new bushing in. No way around it unless you can find a split bushing, but I have never seen one for this application.
Old Nov 7, 2017 | 05:59 PM
civic402lx's Avatar
If u want to avoid doing all of that, then buy new control arm with bushings already installed. Swap them out. Be done with it.
Old Nov 8, 2017 | 01:20 PM
S2k@9K's Avatar
Personally, that's what I would do... The other bushings can't be too far behind. A new OEM arm is around $70.
Old Nov 9, 2017 | 09:02 AM
Baby99EX's Avatar
Can't,broke off both the 14mm bolts, they were super seized......the ones holding the LCA on.......
Old Nov 9, 2017 | 11:51 AM
civic402lx's Avatar
Drill it out. Which one broke off? The one attach to the subframe or the brake?
****, u should drive with it broken anyway. One way or another, you have to drill out the broken bolt. Buy new bolt, grade 8 or higher, and replaced them.
Old Nov 10, 2017 | 11:47 AM
Baby99EX's Avatar
i need to get that old rubber bushing out of the hole on the pass side first........
Old Nov 11, 2017 | 04:45 AM
Baby99EX's Avatar
well the bushings rthe exact samesize as the hole, so they need to be pressed by a machine, sorryijus dont know how to do it.......
Old Nov 11, 2017 | 05:25 AM
civic402lx's Avatar
Didnt we tell you that already? You dont need a machine to press it in. It is the same size because it need to be a tight fit, so it doesnt wobble around causing damage.
at this point, i recommend you stop working on it and have it tow to your machenic. Someone who knows what they are doing.
Old Nov 12, 2017 | 05:09 AM
Baby99EX's Avatar
Here, I am poor. But isnt this part of the old bushing still in there? Just wanted to check before I cut it out.......
