Exactly how bad is my CF mirrors holding up? (Clear Coat)
Old May 26, 2013 | 09:18 PM
mikekh10a's Avatar
Default Exactly how bad is my CF mirrors holding up? (Clear Coat)
I think the correct term is that I need a new layer of clear coat for my Carbon Fiber mirrors, correct? Gel Coat? If I don’t get it taken care of by the end of summer what could happen to my mirrors? Is carbon fiber one of those things where if you don’t fix it right away, it could be non-repairable in the future?
Before anyone asks me about why they’re in such bad condition, I got these APR mirrors for only $40
Driver
Passenger
Old May 27, 2013 | 07:27 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Exactly how bad is my CF mirrors holding up? (Clear Coat)
Sand off the clear and reclear.
Old May 27, 2013 | 07:45 AM
fandsmachine's Avatar
Use 400 when sanding also so you dont see sanding marks through the new clear
Old May 27, 2013 | 08:47 AM
mikekh10a's Avatar
i heard through the grapevine that for carbon fiber, i can't use any old clear coat, is this correct?
dry sand it with 400 grit sand paper, gotcha.
and if i decide to give up on restoring this, can i just paint them? or would they continue to deteriorate? (metaphorically lolz)
Old May 27, 2013 | 09:22 AM
The Grumpiest
Use a clear with UV "resistance". If you paint then it doesn't matter.
Old May 27, 2013 | 09:25 AM
mikekh10a's Avatar
thanks grumblemarc
Old Jun 1, 2013 | 08:06 AM
zArlen's Avatar
Sand with 400 grit until they are smooth, then sand with 600 grit after that. 400 You still may or may not see the scratches in the right light. If it were me I would actually go to 800 but that's the OCD body man in me I guess. 800 is what a lot of body shops use to prep blend areas that need to be re-clearcoated after paint repair.
john159753
Mar 9, 2015 06:30 PM
rathead
Feb 2, 2005 06:32 AM
revolt_allmotor
Jul 23, 2004 01:39 PM
coolasice
Jan 21, 2004 10:07 AM
