Need Help! P/S LS swap in an EK hatch
Old May 26, 2013 | 06:09 AM
importeclipsegst's Avatar
Default Need Help! P/S LS swap in an EK hatch
OK, so heres the back drop. I picked up a 1998 civic DX hatch back that had P/S in it, but only the line is there. I went to Honda and ordered the reservoir, reservoir bracket, the joint tube, and the rubber hoses. I went and ordered a 99-00 Civic Si pump, and the pulley for the P/S pump from O'Riley's. The problem is that the pulleys on the pump and crank are not lining up. The pump and the line fits as they should. I got the P/S brackets from a 91 LS (B18A1), which was what i was told but they guy i bought it from, which i figured would be the same as the B18B1. Here is what gets me, The P/S pump is stamped P72-2, which is my second pumped i ordered. The first one I returned from AutoZone because it was stamped P72-3, which I thought was for a GSR. When I asked AutoZone, they had the same part # for the GSR, LS, and Si, so i figured that was the problem. When I went to O'Riley's they had different Part #, and different Prices, for the GSR and the Si so I thought I had the problem fixed until i got the new one stamped P72-2 and it looks identical to the one from Autozone, and the pulleys still don't line up. I am lost. So a recap of what i am using...
B18B1 motor (P75-6 head stamp)
99-00 civic si pump (Stamped P72-2)
99-00 civic si pulley for P/S pump
B18A1 Brackets (I think, might not be)
98 Civic DX Reservoir
98 Civic DX Reservoir bracket
98 Civic DX rubber hoses
99-00 Civic Si Joint tube
99-00 Civic Si P/S belt.
What am i missing, or what is wrong?
any help appreciated!
Old May 26, 2013 | 10:20 AM
Marvin1985's Avatar
Default Re: Need Help! P/S LS swap in an EK hatch
You need b18b1 ps brackets. Only issue you should of had was wether the line connects
Old May 26, 2013 | 04:06 PM
94EG8's Avatar
Seagull Management
Yeah, the brackets are wrong.
And yes the '99 - '00 Si and all '98 - '01 Integras use the same pump.
Timmay
Mar 30, 2006 02:28 PM
G2TegGuy
Aug 23, 2005 08:43 PM
wreckedmyteg
Feb 13, 2005 09:13 AM
civic23g
Sep 23, 2003 12:16 PM
