Chugging/Stalling feeling when accelerating
Old May 25, 2013 | 02:01 PM
KroniklyFrozen's Avatar
Icon6 Chugging/Stalling feeling when accelerating
Hello,
I have a 1988 Honda accord lx 5 speed - carbureted D series B18 motor. The car feels like it is chugging or bogging down when accelerating. I push the gas all the way to the floor and the car is still bogging/chugging. I have had to put it in neutral rev it and then put it in gear. The idle goes below 1000 and then jumps up to normal on its own. I recently replaced Cap, rotor, wires and spark plugs and put in a cold air intake. Is there something I need to reset? Any ideas or suggestions out there? Thanks in advance!
Old May 30, 2013 | 01:12 PM
skylerreniger's Avatar
Default Re: Chugging/Stalling feeling when accelerating
i had the same problem with my car and mine was a cracked head. i wouldnt just assume thats your problem tho. are you loosing antifreeze at all? does the car run fine when its cold but run like **** as soon as it warms up? you could also try checking your fuel pressure. could possibly be the fuel pump or the fuel filter. with my car it ran really bad when the car was warm. when it was cold the car ran great. eventually i started loosing antifreeze and then soon my head gasket was gone. i ended up just putting a new motor in it and i was good to go. hope this helped you out somehow.
Old May 30, 2013 | 01:13 PM
also ive heard when coil packs go bad the car will bogg when acelerating.
Michael_sloan
May 6, 2016 03:58 PM
PhilMac23
Honda Civic (2001 - 2005)
Nov 5, 2012 11:30 AM
myRice
Nov 20, 2005 11:45 AM
VTECorona
Jun 7, 2004 11:42 AM
snowcrash
Jul 25, 2003 07:58 AM
