Want to Buy Want to Trade/Want to Buy
1999 si driver door
Old May 25, 2013 | 10:01 AM
Em1*99's Avatar
Default 1999 si driver door
looking for a blue 1999 civic si driver door. must be able to put the window up and down with no problems.
Old May 26, 2013 | 09:17 AM
nihad's Avatar
Default Re: 1999 si driver door
You do know there is a way of fixing your 99 civic side window's I fixed mine on my 99ex also when i went to buy after I payed I hit the switch and the window fell off the track I was like what the **** and he was like you hit the switch to hard.. But it was the dumb *** idiots that didnt know how to fix it.. There is a bar that can get adjusted up and down and you have to have it on the right side and also buy some Permatex Silicone spray to lube up the rubber where the window slides up and down on.. But your regulator assembly needs to be adjusted as well tinker with it for a day and you will get it.
Old May 27, 2013 | 07:42 AM
Em1*99's Avatar
I got side swiped in the middle of the night and I rather just spend the money for another door. But thanks for the info the passenger door is starting to have trouble, I thought it was just the weather strip.
Old May 27, 2013 | 10:50 PM
nihad's Avatar
no its gotta get adjusted by the short chanel on the very left side of the door it can go up and down try that out it repositions the window from going straight up to poping back in the guide after it gets half way up just watch the window go up and down.. Also use that stuff in there it speeds the window up this is a huge problem on these ek
:jdmshmaydm:
Aug 31, 2010 07:34 AM
Vinny Chase
Audio / Security / Video
Jun 22, 2003 05:06 PM
MikeMAN
Oct 26, 2002 08:45 AM
