civic fix
Old May 24, 2013 | 09:45 PM
greyEG's Avatar
Default civic fix
Just stumbled across this
http://www.jshmotors.com/jdm-civic-e...d-cut_p416.php
i was wondering how would you replace it? would everything line up ok?
asking because i need some repair on my car
Old May 25, 2013 | 01:08 AM
street93eg's Avatar
Default Re: civic fix
Basically you would buy that piece of the shell and if you take it to a body shop they cut out the bad spots on your car and replace it with the undamaged section. It would get cut with a gas torch or a plasma cutter then the new section would be welded into place.
If the work is done right you will never know anything was done at all.
Old May 25, 2013 | 10:07 AM
sleepyaccord96's Avatar
post pics of the "damage" to your current civic
Old May 26, 2013 | 10:30 AM
greyEG's Avatar
haha not damage its mostly rust so i figure this wud be easier fix a
any more ideas
Old May 26, 2013 | 12:24 PM
B_Swapped93's Avatar
Are you really still going on about those rocker panels ? take it over to a good body shop or sell it.
Old May 26, 2013 | 04:09 PM
street93eg's Avatar
If you got rust and it is a small area then a body shop can typically fix it without to much of a problem. But if it is rusted thru and needs a bunch of work then it will be more labor instensive to remove the damaged section and replace with a clean section.
You could go to a salvage yard and buy the section that you need and have that installed.
A picture would be helpful.
Old May 26, 2013 | 04:12 PM
^ it's the whole rocker panel he's after and that's not a cheap fix
Old May 27, 2013 | 06:04 PM
greyEG's Avatar
i want to keep the car. i dont want to sell it. but i cant figure out what to do about the rocker panels they are rusted thru. like on this
http://www.flickr.com/photos/95378231@N08/8861979062/
its from that civic eg rust fix.com mine is similar to this. i want to fix it. what u guys think
Old May 27, 2013 | 06:06 PM
greyEG's Avatar
this good fix? http://www.jshmotors.com/jdm-civic-e...d-cut_p416.php
or overkill?
Old May 27, 2013 | 07:08 PM
street93eg's Avatar
Well the good news, it could be fixed! But for something like that I would strip the car down to the shell and start cutting out all the rust damage and weld in new steel. The downside to that is it might be cheaper to get a clean shell and work from that. Or get as much of a shell as you can and swap bottoms.
honshu
Jun 12, 2012 03:25 PM
ki0326
Paint and Body
Apr 11, 2012 10:03 AM
Whatislove
Honda Civic (2006 - 2015)
Feb 5, 2009 09:26 AM
EF7
Welding / Fabrication
12
Jan 2, 2009 04:43 PM
AnitRiceSuperStar
Apr 6, 2004 03:04 PM
