is a zc drop into a 88 dx?
Old Oct 23, 2002 | 04:16 PM
MR CRX's Avatar
Default is a zc drop into a 88 dx?
hey a mate here has an 88dx (australian) 5spd and wants to buy my engine (ZC) ...hes just wondering if itd be a direct bolt in?? and also are there any other major hassles?
thanks guys
Old Oct 23, 2002 | 04:38 PM
Blaze45's Avatar
Brrraaaap!
Default Re: is a zc drop into a 88 dx? (MR CRX)
yeah he has 2 injetors and your ZC has 4. he must switch. that is the only difference. good luck.
he needs 89 teg ecu and an injector resistor and some good
instuctions....
Blaze
[Modified by Blaze45, 1:41 AM 10/24/2002]
Old Oct 23, 2002 | 04:46 PM
MR CRX's Avatar
Default Re: is a zc drop into a 88 dx? (Blaze45)
so he cant use my stock ZC ecu??
Old Oct 23, 2002 | 04:50 PM
MR CRX's Avatar
p.s hes getting someone to do it for him so he wont need instructions...hes just trying to get a shoppin list of the stuff hell need and just a confirmation that it aint a hard job..
cheers
Old Oct 23, 2002 | 04:56 PM
wronghand's Avatar
Yes he can use your zc ecu. Here is a very good article that details the entire process. http://hybrid2.honda-perf.org/tech/4gdxtozc.html
Old Oct 24, 2002 | 04:08 PM
MR CRX's Avatar
Default Re: is a zc drop into a 88 dx? (wronghand)
thanks for the link mate but it doesnt work
Old Oct 24, 2002 | 08:08 PM
MR CRX's Avatar
ttt
Old Oct 25, 2002 | 09:04 AM
keithv's Avatar
the link works right now for me, 10/25/02 @ 1:02PM EST.
Old Oct 25, 2002 | 10:27 AM
HF2ZC's Avatar
The ZC will bolt right into the DX chassis and will even use the DX transaxle. But, your friend will have to convert from DX DPFI (2 fuel injectors) to MPFI (4 fuel injectors like an Si or HF). The distributor wiring is a little different than the SOHC Si, though. You can change the DX harness to work with MPFI and the ZC ECU will plug into the same harness end (but will not work properly unless you have converted the harness to MPFI specifications). This link should have all of the info on the conversion: http://dmoore.com/crx/zc-dx-swap.htm
prelude182
Jan 4, 2009 04:12 PM
BlueRex1020
Oct 11, 2006 05:03 PM
SomeDude56
Sep 5, 2005 07:30 PM
Toptul_Honda
36
Dec 26, 2003 08:38 AM
sCeRaXn
13
May 15, 2002 08:59 PM
