conversion help
hey guys i have a d16 ek civic i wanna put a b16a in there if im correct i need a gearbox bracket a t bracket and a timing belt brack where can i get those and is there like online conversion packs i can get ??
you need the rear T bracket
b16 should already have the correct timing belt bracket (post mount)
the transmission bracket that bolts TO the trans you just re use your original d16 bracket.
no there is no such "conversion pack" you must buy these parts individually
i picked up the del sol for 1000 , im new to honda whats wrong with that conversion??? cant find any of these brackets i need some help locating them , if the b16a was coming out of an em1 wouldnt it be the same i know ill need a obd2 harnesss im using a ek4 loom it was out of an auto so i think some splicing needs to be done i just need those bracket no the mounts if it was an eg the t bracket would have clearence
http://www.ebay.com/itm/OEM-Honda-Rear-Motor-Mount-Bracket-1999-2000-Civic-Si-/251240925353?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a7f2048a9&vxp=mtr
^^ there is the rear T bracket you need
http://www.ebay.com/itm/HONDA-CIVIC-96-00-EK-EM-EJ-DX-LX-EX-SI-B16-B18-B-SERIES-ENGINE-SWAP-POST-MOUNT-/321129282093?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ac4cbfa2d&vxp=mtr
^^ there is your driver side post mount
THE PASSENGER SIDE TRANS BRACKET IS THE SAME AS D SERIES.. UNBOLT THE BRACKET OFF THE D16 TRANS AND BOLT IT ONTO YOUR NEW TRANSMISSION.
Machanix262
Sep 29, 2014 09:34 AM
RoTb TwEaK
16
Dec 29, 2011 08:10 AM
ACRProject
Jan 28, 2005 09:54 PM
SI_niki
Apr 28, 2004 04:31 AM
