d16a6 block d15b7 head with a6 cam
Old May 24, 2013 | 06:22 AM
91 EF DX's Avatar
Icon2 d16a6 block d15b7 head with a6 cam
like the tittle says, I have a d15b7 head with its cam, and an a6 cam. There is a d16a6 bottom end at the upull it. Ive read that the heads are the same just the cam is different. So if i use the a6 cam in the d15b7 head on the d16a6 bottom end will i have a legit d16a6? Which would have me useing all the d16 parts like the timing belt, water pump, ect.
Old May 24, 2013 | 06:27 AM
jlicrx's Avatar
Default Re: d16a6 block d15b7 head with a6 cam
yes, the D15B7 head is the same as the D16A6 head - with the D16A6 block, D15B7 head and D16A6 cam, your engine would be the same as a D16A6
Old May 24, 2013 | 06:31 AM
91 EF DX's Avatar
ok thanks man.
Old May 24, 2013 | 07:34 PM
efmartin91's Avatar
You should get a zc cam more a little more aggressive!
journeyquest
Jul 11, 2011 10:58 PM
ef-hatchcrap
Mar 3, 2009 05:50 PM
PA MATT
Mar 13, 2007 12:40 PM
Civichatch27
Sep 17, 2004 03:12 PM
Rob Dizzle
Dec 8, 2003 06:04 PM
