K-Series Injector help
Old May 23, 2013 | 07:23 PM
red96turbols's Avatar
Default K-Series Injector help
Alright so I'm cleaning out my garage and ran across some old injectors from factory and all-motor on my wife's k-series from a few years ago and can't identify which is which, tried google so get off the "Search" **** right off the bat.
Four of the injectors are labled UB11-AASV
Two are labled PE12-PB4
Two others are QA15-ABH
any ideas? trying to sell all this stuff before we move again, I'm tired of moving **** I don't need anymore. Any help would be great.
Thanks
Old Jul 8, 2013 | 06:30 PM
NA_RH707's Avatar
Some injectors are color coded for different CC ratings can you post photos? May help determine if their oem or aftermarket
You could go to a Honda dealership an have them run those numbers to see if their even oem parts that may match your wifes vehicle.
Old Jul 8, 2013 | 07:38 PM
TwinOptiX's Avatar
Default Re: K-Series Injector help
I'm also interested in some info on oe honda/acura injector identification. I have a pile (8) of injectors that were given to me when I bought my swap but don't know if they're 270cc or 310cc.
Old Jul 8, 2013 | 08:10 PM
NA_RH707's Avatar
Should of posted this earlier, hopefully it helps. Follow this link:
http://www.rceng.com/technical.aspx
If you sit down with your current set up specs an use those CC ratings you already know of these calculations should tell you if their good to use on your application or not
Old Apr 26, 2014 | 10:29 AM
JDM BALLS's Avatar
that^^^ has nothing to do with what was asked. im in the same boat, trying to ID some oem K series injectors to see if they are 270 or 310
Old Apr 27, 2014 | 12:01 PM
HiProfile's Avatar
I'm not sure about the numbers, they seem to be more batch numbers than part numbers. I do know the 270cc injectors have a whitish band above the lower o-ring and the 330cc (not 310cc) have a solid black body from the o-ring to the connector.
itr1244
May 25, 2016 11:55 AM
TylerB
Feb 22, 2010 03:51 PM
nokturnal_munkeeboy
Apr 7, 2007 09:42 AM
hondaeg8
Oct 1, 2005 02:18 PM
