Toda, Jun, HondaSaver.....
Old Oct 23, 2002 | 03:37 PM
done's Avatar
Default Toda, Jun, HondaSaver.....
I know this has been beating many many times..
Lately i have been hearing nothing but bad things about toda...
Im looking into either toda Bs or Jun 3s or maybe the new hondasavers....
Pros:
Jun = Peak horsepower is more then Toda, when warm sound almost stock
Toda = smoother vtec engaugement point.. more mid range
hondasaver = said to have more peak then jun
Cons:
Jun = Known to snap
Toda = Known to kill timing belts, to eat rocker arms.... dont idle as well as jun, lobey idle
Hondasaver = brand new, havent fixed the bugs yet.
-Jordo
anyone?
Old Oct 23, 2002 | 03:39 PM
baonest1's Avatar
Default Re: Toda, Jun, HondaSaver..... (Jordo)
got me a set of JUN3's.. the whole head package.. dont got the engine in yet.
Old Oct 23, 2002 | 03:46 PM
Black R's Avatar
25 Year Member
.....go turbo.
Otherwise, those anti-toda myths are bs (imh experience).
If you want a safety net, just drop your car off for a full rebuild on spec D's with sakai. You'll thank me later.
Old Oct 23, 2002 | 03:48 PM
done's Avatar
Default Re: Toda, Jun, HondaSaver..... (Black R)
i do want turbo, but allmotor is what im doing
Old Oct 23, 2002 | 03:50 PM
Black R's Avatar
25 Year Member
.....ok, if you're really a scaredy-cat just do spec a's.
Old Oct 23, 2002 | 03:51 PM
TypeR 599's Avatar
pussay j/k. JUN 3's own
Old Oct 23, 2002 | 03:57 PM
done's Avatar
im not scared, i want the best!! thats why i made this post..
Old Oct 23, 2002 | 04:00 PM
rainmanEK's Avatar
big strong guy
a specs are nice! eric
Old Oct 23, 2002 | 04:02 PM
Reid's Avatar
Global Moderator
Default Re: Toda, Jun, HondaSaver..... (rainmanEK)
Why are you doing all motor if you want turbo?
If you want turbo, do turbo.
Wouldn't that make more sense?
Old Oct 23, 2002 | 04:07 PM
Type R's Avatar
Default Re: Toda, Jun, HondaSaver..... (Reid)
Im guessing turbo = $$ for a good setup. Plus tuning.....
But if you really want turbo just get it dude.
Old Oct 23, 2002 | 04:09 PM
TypeR 599's Avatar
yeah, you'll spend more on n/a to get the same power a turbo has at low boost. plus you want turbo so you'll enjoy it more
Old Oct 23, 2002 | 04:10 PM
done's Avatar
Default Re: Toda, Jun, HondaSaver..... (TypeR 599)
im fine with allmotor
My reasons for allmotor:
I am a jdm junkie....
I want jdm front, oem cleaness
I enjoy shows, and Road racing/autox... thats why i choose allmotor
[Modified by Jordo, 7:18 PM 10/23/2002]
Old Oct 23, 2002 | 04:18 PM
TypeR 599's Avatar
Turbos cost alot... I know allmotor does to, but.. i dont know how to explain it..
my friend spent 2800 for his drag kit, put down 210whp untuned(dynoed 170 stock w/ aem cai) at 4psi. how much would it cost to get 210whp n/a?
Old Oct 23, 2002 | 04:19 PM
done's Avatar
I bet that 210whp allmotor would smoke that turboed 210whp..
Honestly if i want just speed, i would be smart and buy no2, and get bolt ons..
I have a group of friends, they all run 11s, 12s on no2....
[Modified by Jordo, 7:20 PM 10/23/2002]
Old Oct 23, 2002 | 04:27 PM
TypeR 599's Avatar
yeah but 210-220whp is almost maxed out for a n/a ITR(sgt is the exception ). 210whp for a turbo R is probably the minimum, since it was done at such low boost. for that kit atleast
Old Oct 23, 2002 | 04:30 PM
done's Avatar
yeah, man you dont know how bad i want turbo....... but im the kind of person that wont settle for a drag 3 kit.. if i went turbo id go custom
Custom 2.5" intercooler piping
Custom intercoler 20x8x3.5"
Precision pt60
Full Race EQ manifold
Hks SS bov
Tial 35mm hp
GE sleeved to 84.5mm block
10.1 Compression pistons
AEM Standalone...
just some parts .... i wanted turbo soo bad too
Old Oct 23, 2002 | 04:37 PM
PrecisionH23a's Avatar
.....go turbo.
Turbo is the way to go, however the "toda-myth" is not bs. You might not have any first had experience, but a local guy i know shredded 10 teeth on his belt when he was running the Toda B's. And yes, ive read about the Jun's breaking in half as well, remember when you upgrade your motor its not stock anymore so dont expect it to run stock. As far as running the AEM standalone, make sure you have a tuner that knows this system down to a science. Tuning this system is an easy 6 to 8 hours on the dyno IF the base program allows the car to start up.
Old Oct 23, 2002 | 04:39 PM
TypeR 599's Avatar
Precision pt60
Hks SS bov
Tial 35mm hp
AEM Standalone...
if you want it soo bad, i can guarantee you that you wont enjoy the n/a for long. i've driven both, an R w/ a full JUN head package, and a turbo R w/ the drag kit. the turbo R pulled so much harder, even at low rpm and low boost it felt stronger than the JUN 3 R below vtec.
Old Oct 23, 2002 | 04:41 PM
done's Avatar
Precision pt60
Hks SS bov
Tial 35mm hp
AEM Standalone...
if i go turbo, ill never get the turbo kit ..... itll take me to long
Reid's Avatar
Global Moderator
QUOTE]My reasons for allmotor:
I want jdm front, oem cleaness [/quote]
Neither of those things have anything to do with a turbo vs N/A setup.
Turbos get more show points than all motor setups. After all you can't SEE all motor setups, so how can you show them off?
I bet that the turbo car would destroy the all motor car if they both could get traction.
Old Oct 23, 2002 | 04:43 PM
done's Avatar
you guys making me want turbo
Old Oct 23, 2002 | 04:44 PM
Reid's Avatar
Global Moderator
You already want turbo, according to you.
If you can't afford it now, save up.
TypeR 599's Avatar
dude, the drag kit could get you to 300whp(fully built of course), that's not enough for you daily driven?
Old Oct 23, 2002 | 04:46 PM
done's Avatar
i know what the drag 3 kit can do... i like the hondasaver/max rev turbo kit..
Old Oct 23, 2002 | 04:49 PM
TypeR 599's Avatar
so get one
turbo is owning you once again
