92 civic - troubles (machine-gun main relay)
Old May 23, 2013 | 05:29 AM
alfredbb's Avatar
Default 92 civic - troubles (machine-gun main relay)
Hi there,
my wife's civic cr@pped out the other day ... doing just that
dashboard side:
at the intake side:
the sound you hear on the intake side is some sucking (vacuum tubes seem ok)
I thought the relay went bad and got a new one ... same story - so its not the relay.
I disconnected the ecm for 5 mins and the problem disappeared (got NO error codes!) ... but I know it will come back to haunt us in full traffic on a rainy night when trying to escape a zombie apocalypse ;-)
The problem is intermittent - so when DONT get the rapid clicking, the car starts perfectly...
any pointers on how to further proceed with my diagnose?
thx, I appreciate your thoughts/input
Al
Old May 23, 2013 | 05:52 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 92 civic - troubles (machine-gun main relay)
CELs?
Old May 23, 2013 | 06:46 AM
alfredbb's Avatar
Originally Posted by grumblemarc
CELs?
when this happens, the CEL blinks in tune with the klicks - some 5 times per second
so, whenever that happens, I cant diagnose off the ECM
thx
al
Old May 24, 2013 | 09:02 AM
Chris Westlund's Avatar
I left my valve cover ground disconnected after a mini-me swap last week and it did the same exact thing. Check that, and while you're at it check your other grounds as well.
Old May 24, 2013 | 10:18 AM
Former User's Avatar
Have you tried cleaning and tightening the G101 ground on the thermostat housing?
You may also want to replace fuses 31 and 24.
If these don't fix the problem, then you should probably start shopping for a replacement ECU.
Old May 24, 2013 | 02:27 PM
alfredbb's Avatar
ok, will do that ....
hope its not the ecu, as I am living in south america and an ecu would cost more than the car is worth
thx!
al
MonkeyPuzzle
26
May 25, 2009 09:15 AM
vargas
Sep 3, 2008 04:27 PM
neilff
Jul 28, 2003 09:47 AM
