What size tire should I go with?
Old May 23, 2013 | 03:55 AM
poseghatch's Avatar
Default What size tire should I go with?
I have 195/55/R15 right now now and I wanted to run 185/45/R15 but I can't find that size. What size tire should I go with? And my rim is 7.5 inches wide there drag dr20's.
Old May 23, 2013 | 04:26 AM
DeadlockRiff's Avatar
Default Re: What size tire should I go with?
are you going for looks (like stretched or juicy sidewall) or performance and what offset is the rims?
Looking to keep the same height tire or taller? (a taller tire will make your gearing longer)
Old May 23, 2013 | 04:50 AM
cetcivic's Avatar
no one wants to hear the truth
225-50-15
Old May 23, 2013 | 05:26 AM
Originally Posted by cetcivic
225-50-15
205/50R15. Summer tires and competition (no all seasons/winter)
225/45R15. (competition tire size, streetable race tires
225/50R15 is in the same boat as the 225/45, comprising of race tires but there is a very limited selection of regular tires.
Edit 185/45 is ridiculously small in height and width for this rim. Are you looking to stretch? Also if you do go with that I would suggest increasing the spring rate to prevent bottoming out.
that's 2 inches shorter than the 195 not including the height reduction as a result of stretching the tire to fit which would probably be another 1/4-1/2 inch.
Old May 23, 2013 | 05:28 AM
JuggerNaut-CTR's Avatar
Originally Posted by poseghatch
I have 195/55/R15 right now now and I wanted to run 185/45/R15 but I can't find that size. And my rim is 7.5 inches wide there drag dr20's.
What you have now is more safe than what your thinking of getting. Get a tire that fits the wheels!!!! 205 or bigger...
Old May 23, 2013 | 06:05 AM
zamorano's Avatar
I'm going with 15x7 20+ lowered just for daily driving? Is 195/45/15 acceptable
Old May 23, 2013 | 02:51 PM
alphalanos's Avatar
not in my opinion. i was running that setup with 205 easily
B_Swapped93
Nov 25, 2013 12:52 PM
xero_xero
Dec 30, 2012 08:08 AM
theineffable
Honda Civic (2001 - 2005)
Nov 25, 2009 12:58 PM
jdm_j03
Apr 24, 2009 07:27 AM
mjH22
May 6, 2006 02:21 PM
