Header install fitment
Old May 22, 2013 | 02:24 PM
Atomic1's Avatar
Default Header install fitment
Installing a DC ceramic header on my stockish EM1. I cant get the header to fit over the head exhaust studs simultaneously with the exhaust hanger studs (just behind the oil pan). Is there a trick to making it fit? I didn't think I'd have to remove the studs in the head.
Old May 22, 2013 | 02:33 PM
tlarimer's Avatar
Default Re: Header install fitment
Loosen or remove the two 12mm exhaust hangar bolts, up by the oil filter
Old May 22, 2013 | 03:00 PM
nealnanoHX's Avatar
If it is a 2 piece header install the header first then the y pipe if it is a 1 piece the do as tlarimaer said.
Old May 22, 2013 | 05:45 PM
Atomic1's Avatar
It's a 1 piecer. Tlarimer's suggestion worked. Thanks!
Old May 22, 2013 | 07:16 PM
tlarimer's Avatar
Glad it worked out, not my first B16/one piece header rodeo...
Dahl Sol
Nov 30, 2009 01:51 PM
Driven
May 23, 2006 06:43 AM
subtleluck
May 31, 2003 01:20 PM
mrcrimane
Jan 29, 2003 06:10 PM
RStoR
Sep 5, 2001 06:31 AM
