Check engine
Old Oct 23, 2002 | 03:21 PM
turtleb16a's Avatar
Default Check engine
sup everybody.
I get a check engine light once in a while. checked the code, it was 22. Played with the wire to make sure I have a good connection. Read another thread about cleaning the V-tec filter, did that. Reset the ECU.
It ran fine for a while... now I notice it comes on if the car is in idle for more than 5 minutes... its always 22. Do I have to replace the solenoid or are there any other tests i can do?
any help appreciated!!
Old Oct 23, 2002 | 03:29 PM
EL Vap133's Avatar
Default Re: Check engine (turtleb16a)
What ECU are you running? What engine?
Old Oct 24, 2002 | 07:49 AM
turtleb16a's Avatar
Default Re: Check engine (Vap133)
Im using a PWO, checked the engine oil and its fine.
Old Oct 25, 2002 | 09:46 AM
1.7na's Avatar
turtle16a,
I assume this is a b16a swap. Maybe check to make sure the pressure switch moves freely. It may be sticking or something. Not sure why you will only throw a code after your car sits and goes again. Does the CEL come on while you drive on the freeway? Check your wiring?
HTH
1.7na
Old Oct 25, 2002 | 09:50 AM
turtleb16a's Avatar
Default Re: Check engine (1.7na)
It
turtle16a,
HTH
1.7na
It's a B16 swap, the switch is fine, checked the wiring with a buddy of mine and they were good.
anyone else have any suggestions on what to check?
Old Oct 28, 2002 | 10:29 AM
turtleb16a's Avatar
does anyone have an idea?
ek4_b16a
Apr 15, 2009 03:43 PM
DOHC4VTEC
Mar 21, 2008 12:30 PM
eg6turb0
Jul 24, 2004 12:17 PM
chansw
Jun 27, 2004 06:38 AM
staticrex
Jun 1, 2004 11:59 AM
