Jdm Itr Recaros & Itr swap
Jason
Phone: 5157710848
up for sale are my Jdm Itr Black Recaros With rails -$1000
motor -$2200
about 20xxx miles
stroked 1.9 Itr
jdm itr block
LS crank
LS rods, **** peened
USDM ITR Pistons, 1 oversize
build by RS Machine
Aside froM LS crank and rods, all is 97 spec US ITR (manifold,ect)
Estimated 11:1 compression
Head
USDM ITR Head
fully Build by Portflow
Port/Polish
Portflow stiffer valve springs
Full Valve job
Milled 0.020"
-440cc Dsm injectors
-Skunk2 Cam Gears
-Exedy clutch
-Itr fly wheel
-Aem Fuel Pressure regulator
-Skunk2 Composite Fuel Rail
-PasswordJdm magnetic oil plug
-New head gasket -500miles
-New Timing belt -500 miles
-braided fuel lines
-axles
-stock mounts
-shifter linkage with Energy Suspension bushings
-t bracket
tranny -$700
freshly rebuilt jdm itr has 4.785 final drive has like around 5k miles doesnt grind or pop outs gsr dif
Phone: 5157710848
motor -$2200
about 20xxx miles
stroked 1.9 Itr
jdm itr block
LS crank
build by RS Machine
Head
USDM ITR Head
Port/Polish
Full Valve job
Milled 0.020"
-Skunk2 Cam Gears
-Exedy clutch
-Itr fly wheel
-braided fuel lines
-axles
-stock mounts
-t bracket
tranny -$700
