mpfi conversion question
Old May 22, 2013 | 08:29 AM
Zack Gunther's Avatar
Default mpfi conversion question
91 civic dx hatch...
put a p10 im on it from a 92 civic
there are three sensores on it
one on top of the throttle body it is the map and is a three prong plug.
one behind the throttle body i believe it is the tps also three prongs
and one behind the intake manifold not sure what tht is but is a two prong.
iv got the plugs for the the 2 prong one on the back of the manifold and the tps which leaves the map sensor but there is only a two prong plug left but it dosent fit on the map cuz it is three prong. can someone please tell me what im doing wrong
Old May 22, 2013 | 08:32 AM
Default Re: mpfi conversion question
oo and i also converted to obd1
Old May 22, 2013 | 09:20 AM
jimmy o.'s Avatar
The map sensor on a 91 civic is on the firewall unlike 92-00 cars that have em on the throttle body
Either run wires to the sensor on the throttle body or user the stock on the firewall (aslong as it has a vacuum source connected to it either should work fine
Old May 22, 2013 | 09:35 AM
4drEF's Avatar
Keyboard Humorist
The 92~93 D15B7 have a firewall mounted MAP.
94~95 use a TB mounted MAP.
You have something wrong here.
Stock 91 DX MAP has 3 wires.
green/white is C11
white is C14
yellow/red is C15
ef9_civic_hatch
Oct 14, 2014 03:29 PM
upgrayedd
Jun 24, 2010 04:27 AM
chris3385
Jan 3, 2009 04:49 AM
atarigamer01
Jul 1, 2008 07:29 AM
weppskilla
Mar 7, 2006 02:35 PM
