96 civic DX hatch/b16a2 swap - Best octane gas to use?
Old May 22, 2013 | 08:10 AM
gitarman2's Avatar
Default 96 civic DX hatch/b16a2 swap - Best octane gas to use?
I have a b16a2 in a 96 civic DX hatch. From what I have read the recommended octane is 91. The problem is I live in an area that apparently only sells 87/89/93. I was wondering if 89 is close enough to use or will it retard the engine? I know a lot of people mix 87 and 93 to get 91 but seems like way too much trouble to me. Also are there any gas stations that do sell 91 no matter what the area?
Old May 22, 2013 | 08:27 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Best octane gas to use
What ever is recommended by Honda. If you know what is recommended then use it. 91 then would be the minimum. You don't go BELOW what is recommended. That make sense to you?
Old May 22, 2013 | 09:17 AM
Schister66's Avatar
Man U FTW
It means 91+ octane... since 93>91, you're good. Dont mix 87 and 93 because thats ridiculous and anyone who does so has a few screws loose
Old May 22, 2013 | 09:24 AM
ElectronBlue00's Avatar
As others have said, you'll be totally fine.
91+ octain is the recommended amount for that engine. So 93 octain is just fine. Do NOT use anything lower than 91.
Also, as schister said... don't mix the fuels.
Old May 22, 2013 | 11:46 AM
gitarman2's Avatar
Default Re: 96 civic DX hatch/b16a2 swap - Best octane gas to use?
Yikes, when I first got the car I was using 87. What could it have damaged?
Old May 22, 2013 | 11:52 AM
Schister66's Avatar
Man U FTW
You can't really damage anything per se, as the engine has a knock sensor to prevent detonation on less-than-ideal octane fuels. Basically, you will get worse gas mileage and have less power.
Old May 22, 2013 | 12:08 PM
gitarman2's Avatar
Good. Thanks for the help, 93 from now on
Old May 22, 2013 | 12:22 PM
mikekh10a's Avatar
yikes, whenever i'm in west texas for school, the highest octane i see is 90-91. i'm glad to be back in the city..
but yeah anything greater than 91 is fine. does anyone know if there is a reason why odd number octanes are more common than even number octanes?
bonsnick
Dec 1, 2013 11:24 AM
that_sick_eg
Jun 8, 2009 10:42 PM
GoLowDrew
Jul 31, 2008 06:31 AM
explosive
Sep 8, 2004 12:54 PM
HUBB
14
Apr 16, 2003 09:47 AM
