Shorter clutch pedal stroke?
I have a 94 Accord that I race and was curious if there was a mod out there to shorten the clutch pedal stroke? The pedal seems quite high at the top and I know there is some adjustment, but it's still uncomfortable.
Is there a larger clutch master maybe? I've searched but to no avail.
I've asked myself this same question and did some research. Yes you can do pedal adjustments but I don't think it will yield the desired effect of feeling like a new car. I just bought a new master and slave, not installed. I'm not sure if this will again give the desired effect. There is one product out which is the Omnipower master. Check it out
You can control the engagement point by shortening the MC pushrod (it screws up and down) and adjusting where the pedal locks out. If you want to make the engagement window itself smaller, you need a different clutch.
FLCivic
Jun 30, 2004 03:48 PM
