MPFI EF ? HELP
Working on my MPFI swap for my mini me. I understand that C1 and C2 need to be moved to B10 and B12 respectively. My question is, what do I do with the wire that's in the B12 spot right now? It's a white/red wire and I'm not sure what it's for. Any help would be appreciated.
It's been like a decade but if I remember correctly, mine is just hanging. I think it's something unique to the DPFI setup that is no longer used once you convert to MPFI.
Some harnesses are prewired for the automatic transmission lock-up solenoid.
You can depin and let it hang.
- Or you can cut the pin off the old B12 (white/red) wire and use the pin.
- Or figure out where it comes out in the engine bay plug and use it.
sr20paisa
Nov 28, 2016 06:04 PM
EtherEG93
Jul 3, 2008 06:15 PM
