eg swap problems
Old May 21, 2013 | 03:32 PM
jierda eg's Avatar
Default eg swap problems
OK I have a 94 eg swapped with a b18 block and b16 head and I replaced the iacv and now it seems I have a cooliant leak that looks like its comming from my oil pan seal idk any help be great
Old May 21, 2013 | 03:36 PM
grumblemarc's Avatar
The Grumpiest
Default Re: eg swap problems
Hint. Verify exactly where it's coming from. If you haven't gotten under the car, do so. Don't think or assume. Be positive.
Old May 21, 2013 | 04:33 PM
StraussBuster's Avatar
Indeed. If everything was fine before the iacv replacement, it probably means you simply left one of the two coolant lines detached from the new iacv. If not, just search around.
Old May 21, 2013 | 06:09 PM
jdmperez's Avatar
could be your intake manifold gasket
bryansk24
Aug 9, 2017 07:35 AM
eghcivic95
Dec 11, 2009 08:14 PM
hondastreet
Mar 5, 2008 12:36 PM
hybrid2007
Oct 19, 2007 08:16 AM
