B16A2 ACL bearing set oil clearance ?
hey guys, i am puting back together my b16a2 and i need to know the correct oil clearance for the main bearings and connecting rods, i am going to use palsti gauge(green) and i need to know what the right Clearance should be before i do this, i have a new Eagle 4340 cranck and Manley h beam's, and a set of ACL race bearings standard size.
The race bearings are going to give you .018-.020 on an OEM crank, not sure with the Eagle crankshaft. you should also see .016-.018 on the rods with oem crankshaft, again not sure on the eagle crankshaft.
If you within those specs your good to go. What kind of power are you aiming for ? Is the eagle crank stock stroke or is it a stroker crank ? If its stock stroke run your oe crank
thanks, i dont know maby 550-600 whp, cp pistons 9:0:1, manley rods, eagle cranck stock stroke, brian crower stage 2 turbo cams, bc retainers, orbit oil pump, acl bearings, cometic gaskets, rc1000cc, megasquirt ecu, ramhorn with holset hx40 going for 30psi, and alot of other stuff..
it was cheaper and better way for me to get an eagle than buying oem cranck, Eagle says that it is one of the most durable and reliable options on the market and it can handle 1500 hp, so i will give it a go since i bought it already
Understandable seeing you already purchased it, But eagle says it and they break but oem is proven to handle that kind if power
Did your b16 not have a crank. ?
http://www.google.com/search?q=eagle...iw=640&bih=375
...and I thought you were Mr. Domestic?
Given, the Honda threads seem to be lost, but the broken Eagle crankshafts in the Domestic world are still full steam ahead. Eagle is a budget solution through and through...
OP - You get what you pay for...
Crank failures like what you guys claim are actually rare, whether its domestics or 4 bangers. When it does happen, there's usually a mongoloid that built the engine.
The Eagle crank spun itself stupid and turned the engine into flying pieces of metal glory from the looks of it, call Ms. Cleo and she what she says. I don't think anyone here is trying to make stuff up about Eagle out of some sort of personal vendetta, if people here are saying they suck and they actually know their head from their *** then it's probably alright to just accept what they've said and move on.
If that pair of pictures doesn't convince you then you're braver than I. I've never seen or heard about OEM cranks doing anything like that. I wonder how much proof do you need past what has been provided to you before you'll agree you made a risky purchase at best in that Eagle crank.
The image search from that link alone would cause me to shelve it.
If all you know is what you read on the Internet, you're operating under false pretenses.
Well, since I actually machine and build engines for a living and not just read the Internet for knowledge, I've learned that no matter how bad the damage, there's a root cause and its rarely ever simple part failure. There's always extenuating circumstances that someone may be reluctant to explain and would rather say X Brand is junk rather than admit fault. I don't jump to conclusions with just a couple photos.
That crank picture shows a very clear grain break pattern that indicates the beginning of the fracture area.
Well if you're not going to learn from what others teach you then you have to learn from your own experience. That being said I suggest you buy several Eagle cranks and several OEM and do your own testing. Even if someone is to tell you why they're a poor choice you yourself said "If all you know is what you read on the Internet, you're operating under false pretenses.". So keeping that in mind it's basically pointless to tell you anything due to your beliefs. Get off of Honda-Tech and go make your living, cya.
I just don't listen to people who regurgitate what they read. That's why I asked for links, to learn from people with actual experiences. I've actually used a lot of Eagle cranks in the domestic stuff and never had one break. Same for SCAT, Callies, Lunati, etc. I've only seen one break and it was from Crower, one of their baddest BBC cranks and it broke with only 1100hp. Root cause was the owner over tightening the blower belts.
okay my main bearing clearance = .025mm, not 100% the same on all of them, should be good ? still have to check my rod bearings though, i also read somwhere that you should tighten the arp 2000 bolts more than oem spec ?
