Crx a/c addition
Your going to need....wire harness, evaporator w/box, hard lines, soft lines, condensor, condensor fan, compressor w/matching bracket, drier, a/c dash switch. Installed mine last Sept. and it works great!!!!
Good. Make sure you have everything. Even the little brackets that hold the lines. Ya, the harness starts on the inside, goes out the firewall and snakes around to the condensor fan.
NO - not the entire behind the dash harness.
Just the A/C harness.
It has the relays and such as shown in the bottom left of this picture.
Behind the dash it makes two connections.
One is to the A/C switch and the other is to an existing (on all dash harnesses) one wire connector near the ECU (bumps up idle RPM when A/C is on).
JRZ88DX
Oct 31, 2013 12:10 PM
