1996 honda accord cyl 4 misfire
Old May 20, 2013 | 04:55 PM
lfdelar2's Avatar
Default 1996 honda accord cyl 4 misfire
Hi guys so i've been having a weird problem with my honda. About a 2 months ago it began having a misfire on cyl. 4. That is the only cylinder that it misses on. I checked the compression it is fine. Spark plugs are new and so are wires, distributor cap and rotor. I checked the injectors and they are good. Changed the fuel filter and checked the valve clearance. Everything is good!!!! Now ive noticed that the misfire happens when its on operating temperature and not when the engine is cold. I also notice that the misfire happens when I have the A/C off and it goes away when i turn the A/C on. Can somebody please help me out???!!! I am beginning to think that the head is bad!!
Old May 21, 2013 | 10:01 AM
lfdelar2's Avatar
Default Re: 1996 honda accord cyl 4 misfire
i cleaned the IAC valve it was pretty dirty. i figured that when the AC is on the computer opens the IAC valve a bit more to let more air in the engine. I hope my logic is right and the misfire stops
bhangmeter
Mar 16, 2019 08:41 PM
lmt1979
May 9, 2013 07:53 PM
wanting an EF
Mar 2, 2011 07:52 PM
runnels
Aug 9, 2007 12:48 PM
nonbox
Sep 28, 2005 07:47 PM
