Comp Cam Valve springs for forced induction
Old May 20, 2013 | 04:00 PM
flycivicsi's Avatar
Default Comp Cam Valve springs for forced induction
Currently finishing off my turbo build on my Civic.
I am wondering if anyone has any knowledge of the Comp Cam valve springs? Good bad? or stick if Ferrea springs?
Old May 24, 2013 | 04:05 PM
flycivicsi's Avatar
Default Re: Comp Cam Valve springs for forced induction
up
Old May 24, 2013 | 05:28 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
How can we give you advice when no engine was given let alone part numbers or parts? What engine? What cams? What is your goals/boost level? What what what??? Wow, just wow...
Old May 24, 2013 | 05:33 PM
Spawne32's Avatar
up
Old May 24, 2013 | 07:20 PM
flycivicsi's Avatar
I don't see how that has any barring on the quality of these parts. I was asking for reviews on comp cam valve springs...
Thats like me asking if anyone has used an SS Autochrome turbo or just stick a with a Garrett.. then you asking what motor its gong on is it going on?
Old May 24, 2013 | 09:23 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
nevea asked a valid question
if you have gsr cams, then comp cams wouldnt be for you. oem would work best for oem cams
Old May 24, 2013 | 09:35 PM
rich7777's Avatar
Look into Brian Crower's valve springs. They do steel retainers as well which can come in handy for a street car.
Old May 25, 2013 | 12:37 AM
Jimmynitro's Avatar
I've used como stage 2 cam in my lsvtec nitrous car w there recommended spring n titanium retainers,,And rev to 9k+ and they been in the head fir 10-15k miles no probs at all. Raced all they time n beat on hard.
Old May 25, 2013 | 12:39 AM
Jimmynitro's Avatar
N I've had them at least 4 years so far n there still fine,,, I'd get them Again any day.
Old May 25, 2013 | 04:19 AM
DO IT ON ALL FOURS
Clearly you have ABSOLUTELY no clue what you are even talking about. I don't even want to respond but your ignorance is astounding. What may work for one setup won't for another. Different part numbers do have reasons behind this. One manufacture may have a good design for one style engine versus not for another.
Different cams will require different seat pressures and coil bind. Just like higher boost levels accompanied by higher RPM will change the seat pressure required. People need to learn how to factor dynamic spring pressure. Nobody here can read your mind. The ignorant question you posted was just like asking if you prefer wheat or white toast. What style of each? Homemade or manufactured? Butter or not? Jam or jelly? Peanut butter?
Comp Cams is a decent company. They have had issues with Hondas. I assume you are installing some type of D, B, K, J, H, or F series into your ricer Civic and not some of the few SBC's I have seen floating around. Again, you come into the Forced Induction forum and ask "how are these valve springs?" Its not different than going into the Drag Racing section and asking "So, are those Mickey Thompson slicks any good?"
Old May 25, 2013 | 06:29 AM
flycivicsi's Avatar
Comp Cams is a decent company. They have had issues with Hondas. "
That would have been a perfect answer.
Engine
LS block
Darton Sleeved 85mm
JE10.5:1 pistons
bc625+ rods
B16 head port and Polished
Ferrea oversized valved
Comp Cam Dual intake valve springs
single spring exhaust side
Titanium Retainers
Golden eagle intake mani
Brian Crower stage 2 turbo cams
Turbo Kit
GT4276 DBB turbo
Top mount twin scroll
ID2000cc injectors
For power goals I would love to get into the 1000hp range... But I know that wont happen anytime soon.
MatthewMenze
Dec 2, 2012 10:07 AM
Na-Spirit
Apr 19, 2010 02:24 PM
all-mtr-teg
Sep 10, 2009 06:50 PM
Linus_E
Jul 24, 2005 03:36 PM
tek_civic
Jul 7, 2003 10:52 AM
