95 accord sputtering and dying when warm and in gear at idle or light acceleration???
Recently after my 95 accord lx automatic has been sputtering and sometimes dying when sitting at a stop light when in drive. If I shift into neutral before I get to a stop it seems to barely do it at all.
And a couple of times when I go to take off from the stop light it sputters and coughs and will not go/ or it dies. Or I can even floor the gas and it wont go for 5 seconds or so.
If it does die it will just restart and the same problems will happen again.
It does not do it if its cold. And sometimes does the same thing when taking a hard right turn on freeway on ramps.
No codes triggered or check egine lights etc.
Please help.
Iac, or tps? Need to fix it soon.
Thank you for any advice.
Please help.
Dosen't do it at all once I am going above 10 mile per hour. Or on the freeway. It runs perfect at these times, and shifts correctly also.
Just me but I wouldn't mess with the fuel filter.
Instead, I'd start with a good tb cleaning and the IAC cleaning.
We'll assume the tune up items (cap, rotor, plugs, inspect wires, ect) are up to date.
You could have air in the cooling system. Mine is doing some of the same thing and I think that's my exact problem. I just replaced the IACV which helped my idle problem.
Edit:
Actually I may have a bad radiator cap. I suspect it because when I turn off the engine when its hot I can hear air escaping from the cap. That's not normal is it?
Edit:
cap rotor and plugs just done, fuel filter was very dirty.
Problem is still there. I will check the iac, and radiator cap I guess. Problem is getting worse every day. Getting hard to start.
Did you solve this issue? I have same problem with my 99 accord. I suspect the Ignition coil. I replaced my alternator but still have issue. Please let me know!
Hey all, I'm struggling with the same issue. My 99 Accord sputters and dies accelerating from idle, and occasionally dies when shifting from park into R or D. Until recently it started and idled decently, but yesterday on a particularly humid and rainy day, it was idling very rough for a few minutes then evened out... Did anyone find the problem? I cleaned my throttle, IACV, bled the coolant system, I have a new exhaust so not a clogged cat, and I have no CEL so assuming all my sensors are working. I was going to pull off the EGR valve next and see if that's clogged, and then inspect the distributor. Any help greatly appreciated!
Ntense_Civic
Apr 20, 2012 04:47 PM
integra_661
Dec 8, 2011 12:56 AM
