wheel bearings/hub 5 speed swap?
Old May 20, 2013 | 09:59 AM
hon2984's Avatar
Default wheel bearings/hub 5 speed swap?
whats up guys...got a friend preparing for an auto to manual swap in a 89 dx auto. He has a donor car 91 si with a zc swap and 5 speed. I looked up the part numbers for the auto hub it is 44610 sh3 981 for the 91 5 speed it is 44600 sh1 A00. With the auto wheel bearings work or do they need to be transfered from the donor car?
Old May 20, 2013 | 10:27 AM
4drEF's Avatar
Keyboard Humorist
Default Re: wheel bearings/hub 5 speed swap?
Why are you swapping out hubs?
You don't need to.
Axles swap right in with no issue.
If you had an HF or an STD model, then you would have issues.
You didn't mention if you had the DOHC ZC transmission.
This uses the intermediate shaft and Integra axles.
With that setup, you would have to remove the dust seal off the backside of the hub.
mario_pic
Aug 14, 2008 12:04 PM
welfarepc
Jul 8, 2007 11:56 PM
latinracerct
11
Oct 12, 2006 10:23 AM
hb_guy
Oct 13, 2005 11:29 AM
speedy-crx
Oct 2, 2002 05:49 PM
