IAT steel flanges, any sources?
Old May 19, 2013 | 04:50 PM
KevinEF7's Avatar
Default IAT steel flanges, any sources?
Hey guys, I am in need of a flange to weld onto my charge piping for an IAT sensor. Is there any places that have a steel version?
All i see are aluminum versions, but my pipes are steel so thats what I plan on using
Im guessing the flange would just get welded straight to the pipe the best you could? Flange being flat and pipe being round...
Old May 19, 2013 | 08:05 PM
UTAH TSX's Avatar
Default Re: IAT steel flanges, any sources?
I need some steel ones too, guess we could make them.
Old May 20, 2013 | 03:28 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Just weld a nut on and convert to the CRV IAT... That would be much easier than hee-hawing around. You could grind the nut round and paint or polish it if looking at one more nut in your engine bay bothers you. Or just hide it. The wiring is snug, but with some work you can put the pigtails into the OBD-2 clip. I have done it MANY times before...
Old May 20, 2013 | 03:58 AM
jimbo slice's Avatar
Or make a threaded bung for a GM IAT sensor. The thread size is 3/8 NPT, so making a threaded bung should be easily accomplished.
Old May 20, 2013 | 04:15 AM
Black R's Avatar
25 Year Member
It's literally 3 holes.
I'd be inclined to just drill the steel charge piping and tap two of the holes.
Old May 20, 2013 | 04:20 AM
UTAH TSX's Avatar
I would but I'm using hondata flash pro on stock ecu dont think gm sensor is in the same votage range, Iknow they are much faster would be nice if it worked.???
Old May 20, 2013 | 05:01 AM
DO IT ON ALL FOURS
Wouldn't the K-series IAT and plate work better for your application if that is the case?
Old May 20, 2013 | 05:04 AM
DO IT ON ALL FOURS
If you didn't do it right you will crack the sensor. The center hole is recessed for the O-ring and its "guide". The O-ring is what seals it so if you were to do your route you would need to come up with a gasket or layer on the RTV - yuck.
Old May 20, 2013 | 05:48 AM
Turbo-LS's Avatar
I had steel charge pipes years ago. I just drilled the three holes put screws from the inside of the pipe with nuts on the outside and red locktite. then put the sensor on and two more nuts to hold the sensor on. worked like a charm
Old May 20, 2013 | 06:49 AM
KevinEF7's Avatar
I would definetely like to retain the stock sensor. This car is OBD0 and everything works, dont wanna mess around to much
I never thought to simply drill and tap the charge pipe, possibly hammering it a bit flatter where I want to mount the sensor.
I wouldnt think there would be enough meat there in the sidewall thickness to get a decent thread, I'll try on a piece of scrap Ive got laying around from pie cuts
Old May 20, 2013 | 07:15 AM
lsturbo33's Avatar
I can cut you one whatever thickness you want on one of the cnc machine here. PM me if your decide you still need one.
Old May 20, 2013 | 09:44 AM
Turbo-LS's Avatar
You could also go to lowe's and buy a piece of 1/4"weldable flat steel for 10 bucks and cut a piece off drill it tap it and weld It to the charge pipe
KevinEF7's Avatar
From what I can tell there is knowone selling them at all you should make a little run of them to make some $$ I will buy one for sure, not to picky on thickness, 1/4-3/8" should be fine
If youre able to do it I would love to buy one
Old May 20, 2013 | 09:45 AM
KevinEF7's Avatar
Originally Posted by Turbo-LS
You could also go to lower and buy a piece of weld able flat steel for 10 bucks and cut a piece off drill it tap it and weld It to the charge pipe
My diy flanges always look poopy, sure they work, but rough angles and dull drill bits are just no fun. CNC flange for a few bucks to save time and look smexy would be ideal.
If it came down to it though yes I have the tools to make one in an hour or so
Old May 20, 2013 | 10:12 AM
Turbo-LS's Avatar
There ya go, i would make one and not get fancy with it just rectangular shape big enough for the sensor to ride on and geta nice weld on it if you do end up making it your self. Also put it on the underside of the charge pipe and you wont have to look at it.
Old May 20, 2013 | 10:28 AM
I've gone from a GM sensor to a Honda sensor and back ( thinking the same as you about the range ) and never once saw any difference. This was on a Neptune powered crx
Old May 20, 2013 | 08:05 PM
project dc2's Avatar
use a b20 IAT sensor
12X1.5 thread pitch . can use a nut or get a steel bung and tap it
Old May 21, 2013 | 03:26 PM
KevinEF7's Avatar
Plugs into the factory harness? Where is that sensor located on the b20 engine?
Old May 21, 2013 | 05:01 PM
DO IT ON ALL FOURS
http://www.hondaautomotiveparts.com/...NIFOLD+%281%29
Intake manifold - #16
Old May 22, 2013 | 05:48 AM
Turbo-LS's Avatar
Yes it plugs rigth in. Its the same sensor internally and plug wise just screws into the intake manifold VS the style that is held on with two screws
Sprockets
Aug 11, 2008 03:43 PM
AirWaveGT
Welding / Fabrication
Nov 29, 2004 03:51 PM
DubyaAye
Mar 20, 2004 08:43 AM
pub
Mar 24, 2003 04:01 PM
Wo-Nelly
Dec 28, 2002 06:50 PM
