FS: IL: 8 Blade Holset HX35 - Other Good Stuff
I have quite a few things for sale. I do not have pictures of everything with the HT requirements yet but I am working on it. The pictures I do will be uploaded.
Prices do not include shipping or Paypal Fees.
Holset HX35 8 Blade Turbo - 12cm2 turbine housing blocked off wastegate and 3" VBand welded on. Turbo was just rebuilt apx 1000 miles ago by a reputable diesel shop. Only reason for sale was thought something happened to turbo, ended up blowing out a weld on the wastegate flange. Turbo is ready to bolt on and run.
$350
Walbro 190LPH Pump. Ran for a year or so on a stock H22 in a Civic Works great, just replaced with 450 pump.
$50
I will include pictures of the rest later with proper requirements.
OBD2 H22a4 Head - Resurfaced (.008) - Seats cut (5 angle) valves reground and vacuum tested. Cam bores checked and head cleaned. Comes with all caps, including VTEC solenoid.
100% ready to run.
$350 OBO
H22a4 Block. Needs honed/dry sleeved (possibly) - Comes with all caps. Deck is flat. NO cracks.
$175
Buddy Club N+ Coilovers for RSX. 02-05? Mileage is low, were just taken apart, cleaned and setup for apx. 1" of drop and settings according to BC specs. Read to install and go.
$750 OBO
Fidanza 8lb flywheel and Action 6 Puck Sprung Clutch. Less than 2000 miles - Did not slip when removed but does have some heat marks in it. Was ONLY removed to install a Comp. Twin disk for the added power.
$125 OBO
$350
$50
100% ready to run.
$350 OBO
$175
$750 OBO
$125 OBO
triskpin
Aug 29, 2012 06:05 PM
MAFDARK
May 20, 2011 07:57 AM
KTULU990
Feb 2, 2010 09:02 AM
turbopanda
Jan 19, 2003 12:17 PM
