1991 crx rims, how big can I go?
Old May 19, 2013 | 07:16 AM
claymillerjr0's Avatar
Default 1991 crx rims, how big can I go?
I currently have a nice set of 15" rims but I would like to go with a different style how big can I go without it rubbing? Any thoughts!
Old May 19, 2013 | 08:15 AM
ownedevo10's Avatar
Default Re: 1991 crx rims, how big can I go?
Explain what you mean by bigger? Are you asking if you can fit 18s or are you asking if you can fit like 15x8s without rubbing?
Old May 19, 2013 | 09:42 AM
bheinen74's Avatar
You could fit up to about 35" on
Old May 19, 2013 | 01:07 PM
Well I just want to put some nice rims on it without rubbing and I don't want it to look ghetto.
Old May 19, 2013 | 05:49 PM
F22Master's Avatar
It's more dependent on tire size. On my EF, 205/45-16s fit fine, but 205/50-16s rub like crazy front and rear. So with a thin sidewall, you can fit 17's, maaaaybe 18's.
Old May 19, 2013 | 07:59 PM
Dark_Teg's Avatar
Anything bigger than 16's tends to lift a CRX and make it look like a 4x4. I think 15's look perfect.
Old May 19, 2013 | 08:06 PM
ss_zoidberg's Avatar
Can't lose on 22's
Black R's Avatar
25 Year Member
IMO a nice wide 15" is where it's at on this chassis.
Old May 20, 2013 | 04:16 AM
zapzach's Avatar
i have 195/45/16's and lowered 2 inches with no problems.
15" is usually your best bet. you may be able to pull off 16".
17"+ is overkill.
Old May 20, 2013 | 08:43 AM
th3pwn3r's Avatar
Originally Posted by ss_zoidberg
Can't lose on 22's
That's exactly what popped up in my head. Btw, I fit 225/50/R15s easily on my CRX on some Enkei RPF1s, I think 235s will fit but I'm not positive.
Old May 20, 2013 | 09:02 AM
Thanks for the input guys
Old May 20, 2013 | 02:18 PM
Black R's Avatar
25 Year Member
275/35/15 IMO.
Old May 21, 2013 | 01:21 AM
LudeEFv2.4's Avatar
My old title sucked.
I have a sneaking suspicion that car can make corners at a high rate of speed.
Old May 21, 2013 | 05:53 AM
th3pwn3r's Avatar
If he has enough power to turn those massive wheels :D
Old May 21, 2013 | 09:53 PM
89ED's Avatar
are those 8 8.5 or 9 inch wheels
Old May 22, 2013 | 04:17 AM
Spug's Avatar
Offset?
Old May 22, 2013 | 04:27 AM
robbym9821's Avatar
what about on a 92 del sol? whats the biggest you can go
Old May 22, 2013 | 04:30 AM
Spug's Avatar
Try the Del Sol forums?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/
homero
Apr 8, 2012 02:51 PM
myed9crx
Nov 26, 2010 01:43 PM
Didly
10
Dec 8, 2009 08:47 AM
jdmef8vtec
27
Mar 1, 2007 07:57 AM
Magnum000
Jul 11, 2004 07:26 AM
