HELP SPUTTERING!
What will cause really bad sputtering and missfiring in a 91 honda civic? Timing is good, smells really gassy. I put new spark plugs and wire in along with a new fuel filter. Also i accelerate really ******* slow, even when reving it wont rev up to red line.. Thoughts and ideas please
my 91 civic does the same thing, d15b2 engine, might not even be relevant. The sputter is worse off the colder it is. MY spark plug wires are popping off due to bad o-rings. It's run like this for thousands of miles. Common issue as far as I know. It feels like I'm running out of gas, but the car has never cut out from the issue.
mine's an automatic, since you can see your redline, I figure you're driving a stick. have a look at the o-rings under your spark plug wires.
bignosewhipper
Dec 26, 2013 10:00 PM
UNDER PRESSURE
Oct 23, 2007 12:34 PM
AutoboTxEK
Apr 3, 2002 09:49 AM
