lowering
Old May 18, 2013 | 03:49 PM
Honda4Life910's Avatar
Default lowering
what the best and most comfortable setup for lowering an eg hatch?????
spring or coils???
springs and struts???
Old May 18, 2013 | 03:51 PM
grumblemarc's Avatar
The Grumpiest
Default Re: lowering
No such thing as best.
Old May 18, 2013 | 03:53 PM
B_Swapped93's Avatar
the "best" is what's in you budget works gives decent ride comfort and won't brake in a year. but in short so such thing as best depends on why you want from the set up
Old May 18, 2013 | 03:54 PM
emergencybm's Avatar
Very subjective.
BEST: not lowered.
Old May 18, 2013 | 03:56 PM
pun1shr's Avatar
Swapped my stock springs/shocks for s techs/blues. Rides great.
ThunderToe's Avatar
15 PSI in 3 tires. 25 in the fourth. Doesn't matter which one as long as its rotating in the opposite direction from the other 3. Use your stock struts. The more broke in the better. Get springs from a chevette. But it HAS to be pre '82 for the rates to be right. SLAM DAT **** SON!
NOW, take all the information I gave you and research and come up with your own ideas for whats right for you just like the good ole days before everybody got lazy as **** and wanted everyone else to hand feed them.
Old May 18, 2013 | 03:57 PM
The Grumpiest
Please quantify "ride great".
Old May 20, 2013 | 12:37 AM
I really wanted to.go skunk2 procs or s's
Old May 20, 2013 | 12:46 AM
jbpnoman's Avatar
There is no such thing as "low and comfortable". Lower inherently means less room for suspension travel. "Comfortable" generally means the suspension can absorb bumps and imperfections in the road without the body of the car having to react. Going lower means using higher spring rates, which will make the suspension "snappier", but you'll feel the difference.
On top of that, you have the effects of your tires. Softer tires, with a softer and larger sidewall, will absorb those little bumps and imperfections much better than performance oriented tires, which are made to maintain traction and road feel.
If you want it to stay comfortable, stay at stock height, with 13" or 14" wheels, and full-sized tires. Modern true sports cars can be comfortable because they have $10000 suspensions under them - your car does not, and cannot.
Old May 20, 2013 | 11:33 AM
johnjohn316's Avatar
eibach pro kit
Old May 20, 2013 | 03:25 PM
pun1shr's Avatar
Rides like right out of the showroom stock. Does not ride like its lowered whatsoever, which is exactly what I was looking for, and what I believe the op is looking for.
Old May 20, 2013 | 04:29 PM
Eddie's Avatar
Master Ninja
The lower you go OP the ride quality get's worse.
Old May 20, 2013 | 04:59 PM
OmgDelSol's Avatar
Don't waste your time with the cheap brands. Stick with progress CSII or Ground Control/Koni. If those aren't in your budget then save up until it is.
mdpsEG
Suspension & Brakes
Jun 13, 2008 09:55 AM
gras
Honda Civic (2001 - 2005)
Feb 5, 2008 07:51 PM
ZakkWylde
10
Jun 1, 2007 08:30 AM
DualCamDan
Sep 9, 2004 09:15 PM
vi3t187boi
May 16, 2003 04:17 PM
