Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
08 Civic, A/C compresser won't come on, freon is full.
Old May 18, 2013 | 03:19 PM
Ohmster's Avatar
Icon2 08 Civic, A/C compresser won't come on, freon is full.
Guys,
I have a 2008 Honda Civic which I love dearly. Has 95K miles, bought from dealer few years ago, used with 56K. A/C went out, dealer fixed it. Found low pressure hose fill valve leaking, replaced. Also replaced cabin air filter and inside/outside air door actuator. Cold as could be, lasted almost two years.
About a week ago, I noticed the A/C cutting out, shut it off, come back on cold, would not stay cold. I went to a friend, he put refrigerant in it with the parts store fill can. Compressor came on, nice and cold, compressor stopped again, will not come on at all. I bought another can of refrigerant with a reusable gauge on it, and the freon is not low at all, it was quite high. I bled some off, still, the compressor will not come on at all. Must be electrical and I am an electronic tech, but I cannot find any sort of service manual or electrical diagram for a 2008 Honda Civic, anywhere. Yes, I am too poor to buy one, waiting on medical disability claim stops me from working.
I thought there was a refrigerant pressure switch, too low and stops the compressor to avoid burning it out. I cannot find one in the car. I hear there is a temperature switch on the compressor and another switch for something under the receiver/dryer in the passenger cabin. Not easily accessible. I can check switched with a digital meter, but the compressor cable has 3 wires. Not sure what other sensors there are and how to get to the connectors. Also I understand there is an A/C clutch relay which I can check if I knew where it was and which one in the box under the hood.
I attached some photos of the car, the refrigerant lines, the compressor, and the main fuse/relay box. I can test fuses and relays, but not if I don't know which ones they are. Nothing in the main box is labeled as "A/C" or "Compressor". So I have no idea of what to check. The compressor does work, the system is fully charged with refrigerant, and the compressor clutch never comes on at all anymore. Any ideas?
I tried using Civic manuals from different years but they are not help at all with this car.
Can someone give me a heads up here please as to what to look for, where to find it, and what to check? A service manual, pictures, diagrams, and part details would be a huge plus. Please, I really need your help guys.
Old May 22, 2013 | 09:31 PM
go-part's Avatar
Default Re: 08 Civic, A/C compresser won't come on, freon is full.
http://www.wikihow.com/Fix-Your-Car%27s-Air-Conditioner
Old Jun 3, 2013 | 09:28 AM
boostedh22fag's Avatar
probably the relay
Old Jun 4, 2013 | 05:56 PM
DELuth's Avatar
Man I love it when people just blindly slam more refrigerant into the system. Over-stressed hoses and compressors = $
Judging by that HUGE gap, you probably need a new clutch (and maybe coil). Relay is also a possibility, but between the mileage, that pic, and the fact that those clutches suck, I say clutch. You need a mechanic, not internet repair advice.
Old Jun 12, 2013 | 10:11 AM
jeddy0120's Avatar
Just dealt with the same thing on my wifes 2008 Civic with 100k on it. The coil ended up being bad on it. Even though the coil is a serviceable part I chose to replace the compressor with a reman'd unit from Honda (when replacing the coil you can ruin the gasket on the compressor and then it can leak bringing you back to square one so, I opted for a full replacement.). All said and done with a new drive belt the total was a little over a grand.
Old Jun 21, 2013 | 09:13 AM
Nathan Allen's Avatar
Did you have the system evacuated before you added Freon? Also, what is your Freon psi reading? Before and after charge?
Old Jun 26, 2013 | 01:29 AM
airfactory2003's Avatar
Check the current to the compreesor,if ok,then check compressor coil (4 Ohm) and thermal sensor located on the top of the compressor.
alloysr16s
28
Jun 24, 2016 01:50 PM
prodjay10
10
May 22, 2016 09:43 PM
jcorv
Jul 10, 2012 10:50 AM
Spoon4door
Aug 14, 2004 05:44 PM
