where to connect FITV hoses on em1
Old May 18, 2013 | 01:08 PM
luuisss's Avatar
Default where to connect FITV hoses on em1
Ok so my b16 gave out on my em1 and i swapped in a b20 since it was cheap :/ but ok heres my problem. i put on an ls manifold and idk what these two nipples go connected to. my cars idle would fluctuate. then i plugged the coolant hose, ran a U hose and basically connected the two nipples with one hose and plugged the second nipple on the back of the manifold by the clutch/ brake fluids. nnow my car idles kind of normal but still fluctuates minimally under the 1k rpms range. the throttle body is what i think would be my stock em1 TB but not 100% sure about that. any help will be greatly appreciated. no CEL's as well.
Old May 18, 2013 | 01:09 PM
luuisss's Avatar
Default Re: where to connect FITV hoses on em1
these are the two nipples on the TB and the plugged coolant hose right under it.
Old May 18, 2013 | 01:35 PM
silkypillows's Avatar
the plugged hose goes on the nipple to the right.
the left nipple leads to the IACV - out from IACV to the coolant tube that run along the back of the block.
Old May 18, 2013 | 01:45 PM
luuisss's Avatar
Thank you, will take a look when i get home and update
Old May 18, 2013 | 02:58 PM
luuisss's Avatar
What about the second nipple on the back of the intake manifold?
Old May 18, 2013 | 03:27 PM
coming from the iacv or the left nipple on the TB?
from left nipple in pic - to IACV on back of manifold - out from IACV to the coolant tube running across backside of block, under the manifold.
Old May 18, 2013 | 06:11 PM
luuisss's Avatar
no theres two nipples behind the manifold by where you put the clutch fluid. i put one vacuum hose on the outside one but theres an empty one next to it and idk what goes there
Old May 19, 2013 | 02:12 PM
can you take a picture? I believe..large nipple goes to Brake booster and small nipple goes to your cruise control diaphragm (if using it)
Old May 20, 2013 | 09:45 AM
luuisss's Avatar
not my pic, but these two. my car only has one hose coming out from the firewall area and i plugged it into the outer one. idk where the inner one goes to so i just plugged it.
Old May 20, 2013 | 08:12 PM
luuisss's Avatar
any help
Old May 21, 2013 | 11:54 AM
One of these might answer your questions
B18A1 vacuum diagrams:
http://tinypic.com/r/2nrh735/5
http://tinypic.com/r/4fu4cg/5
B16A2 vacuum diagrams:
http://tinypic.com/r/f1wcw5/5
http://tinypic.com/r/34zaq7d/5
Old May 21, 2013 | 05:39 PM
luuisss's Avatar
but b16 doesn't have a Fuel pressure regulator control solenoid valve thing. Unless im blind?
Old May 22, 2013 | 08:53 PM
luuisss's Avatar
ttt
Old May 23, 2013 | 10:08 PM
luuisss's Avatar
Anyone...
Old May 27, 2013 | 01:46 PM
luuisss's Avatar
bump
90CB7EX
Nov 10, 2016 04:13 PM
Mark96Ex
Nov 29, 2008 12:50 PM
.one lane
Nov 13, 2005 11:41 AM
StolenTeg
Nov 14, 2004 01:08 PM
nacho_man
Nov 13, 2004 04:52 PM
