Jdm gsr wiring with usdm p72
Old May 18, 2013 | 12:19 PM
Wol4's Avatar
Default Jdm gsr wiring with usdm p72
What all wiring needs to be added, switched up, and spliced to make the jdm gsr run properly on usdm p72? I know u have to add vtec, iab and knock and jump vtec pressure switch and ckfp, ckfm. I also know the jdm doesn't have the evap purge controle solenoid valve. So should I be putting voltage to the evap pin on the ecu to trick it so it thinks its hooked up?
Old May 18, 2013 | 01:27 PM
racebum's Avatar
Default Re: Jdm gsr wiring with usdm p72
you need a usdm gsr harness, usdm oil pump, usdm cfs sensor, usdm crank sprocket, usdm vtec switch, usdm evap solenoid and that should be it. the secondaries should already have a solenoid in place
PIntegraMP
Apr 9, 2006 02:25 PM
Gr8Wyt3
Dec 2, 2003 05:56 AM
Judah
Sep 23, 2003 05:34 PM
SlipoftheCondom
Nov 26, 2002 09:08 PM
