Weird beeping
Hey all,
Yesterday while I was driving around my 91 Dx hatch started beeping under the dashboard a whole bunch on the passenger side, I pulled into a safe place, and checked that little window thingy with the blinking light, there was 1 flash then 16 which I take is a code 16...which I've gathered is something to do with a relay or something to do with the car not starting..... The weird thing is she fires up and runs fine.... oddly enough I just put some oil in (it was about a quart low..) kicked the quarterpanel a couple times cause it was irking me, and it quit beeping....
Guess my question is: What's the problem, is it hard to fix, and is it expensive?
Your ECU is throwing codes at ya there man, specifically a code 1 and code 16. In other words, despite if she seems to be doin hot, your computer is saying otherwise. Check this link for the codes: http://crxcommunity.com/viewtopic.php?t=9903. The code 1 is your O2 sensor, and the 16 is your fuel injector. To fathom a guess, I would say that the ECU is picking up a strange mixture of fuel and air. That or one or two of the above items have come unplugged... Just a thought to check.
bgcrx
Feb 21, 2008 07:24 PM
