DA and DC Bushings
Old May 17, 2013 | 10:52 PM
ParadoxTeg's Avatar
Default DA and DC Bushings
I had a fairly stock 97 LS which I recently sold in order to buy my buddies 92 GS w/ LS/VTEC Turbo.
My question relates to the Energy Suspension master bushing kit that I was going to install on the 3rd gen, but never got around to.
Are any of the bushings from the 3rd gen kit compatible for use with the 2nd gen Integra?
Thanks.
Old May 19, 2013 | 11:46 PM
ParadoxTeg's Avatar
Default Re: DA and DC Bushings
No one has any idea?
Old May 22, 2013 | 01:59 PM
ParadoxTeg's Avatar
Old May 23, 2013 | 11:13 AM
ParadoxTeg's Avatar
Well I did some investigating and found my answer, figure I will share it here in case anyone else wanted to know.
According to the part numbers in the two master bushing sets the following are the same between the two generations:
- Rear LCA
- Front End Links
- Tie Rod Boots
- Front Ball Joint Boots
- Transmission Shifter Stabilizer Set
- Front and Rear Shock Sets
So basically everything except the front control arm and steering rack bushings appear to be the same parts in both kits.
Old May 23, 2013 | 11:17 AM
ParadoxTeg's Avatar
And the steering rack kit has the same drivers side bushing, the passenger side is a different part number.
e-honda
Sep 8, 2006 02:28 PM
jeffh
Jun 13, 2005 07:34 AM
VSBB6
May 31, 2005 11:20 AM
