ground for injectors
The injectors always have 12V power, the ECU grounds them and thats what makes them pulse.
Make sure your ground at the T-stat housing, valve cover, transmission, and chasis are all in good working order.
Low impedance injectors with resistor box or High impedance Injectors without a resistor box?
If you got new ones with High Imp then you need to take out the resistor box or they don't have enough current to fire.
If you got low Imp and you took off the resistor box then more than likely you blew up your ECU already
So when I unplug that resistor box the car won't even start but when I plug it in the car starts and sputters and then dies would that be the resistor box or the computer
I've been trouble shooting hence the injectors aren't working after I cleaned all my grounds and check all the wires to the injectors.... You bing a dick isn't helping me figure out the problem
OMG. You can't just unplug the resistor box and turn the car on and off keeping your fingers crossed hoping something MIGHT work. First and foremost, check grounds like others have said. Confirm 12V at the injectors. Confirm what type of injector you have by testing with a Multimeter (unplug injectors, test resistance). Better yet: a quick google search yielded this: http://www.hondata.com/techlowohminjectors.html
Have you tried pulling main relay and check if the solder is broken? If it is either resolder or get a new one. does it have fuel to injectors?
turn the key to the second position and make sure the check engine light goes on then off. then wait about 20 seconds with the key still in the on positon and see if the light comes back on. if it does check the code. gotta start at the beginning of the diag tree.
Will do but I'm pretty sure it doesn't I've tried before.... I also heard the crank position sensors can keep it from running but would it keep the injectors from spraying
