how much did you pay , to fix your oil leak ?
im having very bad oil leak problems , leaking from a h22 engine , in the tranny side , and the driver side . there big as the top of a plastic cups , i need it to get it fix , if anyone ever had this problem , how much did you pay to fix it , so i know what to look for , i know all shops are different , but still would help me :/
simple things like oil pan gasket or axle seals under 100$ would be fair.. much worse would be crank seals. that could be upwords to 300$. could possably be a major valvr cover gasket leak. wich would just soak everything but is one of the easier things to fix. you need to in ther and look at wher the oil seems to be coming from.. trace it upto the highest point. look at the oil filter area. around the axles that exit the trans. around the head.
