205 50 15 t1r or 195 50 15 r1r
Old May 16, 2013 | 04:11 PM
eg.reddragon's Avatar
10 Year Member
Default 205 50 15 t1r or 195 50 15 r1r
I thinking few weeks ago and still no solution. I got an eg civic with b18c4. The eg civic stock size 195 50 15, for the b18c4 is 195 55 15 (205 50 15). The first, i dont kbow what size of tyre i have to use. Other is: 205 50 15 t1r £55 195 50 15 r1r £69. Which is will be the better? Bigger cheaper street tyre or smaller expensiver street slick? Sorry for my bad english! Andrew
Old May 16, 2013 | 05:32 PM
toyomatt84's Avatar
Sanji
Default Re: 205 50 15 t1r or 195 50 15 r1r
You'll want to use the tire size dictated by the car's chassis, not the drivetrain. So, 195/50/15's would be the size to work around.
Depending on what kind of tires you're looking at, you may want to go with the 205/50/15's for an increase in contact patch size. But, then again, you could be looking at All-Season tires versus Summer tires... which are two completely different types of tire.
Old May 16, 2013 | 08:39 PM
jdmh22eg2's Avatar
Also keep in mind that with toyo r1r (maybe t1 also) but i KNOW with r1r their "205" tire acually is near a 215. They are never a correct size. Idk why but my 215 r1r's were damn near a 225
Old May 16, 2013 | 11:27 PM
10 Year Member
I just wanna get more grip, now i have 195 50 15 paradas. Thats why i am stuck, i dont know what will be the better. Bigger size street or same small slick. I got r1r before, that is awesome tyre, but my friends integra got t1r and he said it's superb!!! I never used t1r yet. TOYOMATT84 --> the eg vti stock size 185/65r14-->205/50r15 my one was esi what is 195/50r15 so the speedometer will show 2-3mph less if i choice the 205...
Old May 17, 2013 | 10:57 AM
TunerN00b's Avatar
They may run wide, but the diameter will be correct for the listed size, which is what matters more here.
Old May 17, 2013 | 11:18 AM
jdmh22eg2's Avatar
^ yes that will be right but if your looking for a particular width as advertised and its almost 10mm WIDER that is BS. I had to reset my suspension and recorner balance my car, not cool because of a a oversized tire.
Old May 17, 2013 | 12:22 PM
TunerN00b's Avatar
I think you might be looking at it the wrong way. They're (assumed to be) oversized for people who compete in classes that limit tire size.
I don't understand why you'd need to re-corner balance the car. If you raise all 4 corners the same amount, the balance should be unaffected. I raised the front of my car 1", left the rear alone, and the cross weights stayed the same.
B3AS
Oct 25, 2006 10:58 AM
EMphaticONE
Nov 1, 2004 04:28 PM
integraboi1010
Jun 11, 2004 10:33 AM
BoostinEJ1
Mar 8, 2004 02:10 AM
1stealthls
Feb 7, 2003 11:22 AM
